Latency spikes
Started by AzShane, Dec 10, 2011, 18:12:33
AzShane
Have been experience spikes in latency since 2pm on friday. Im on Home SuperPro LLU, on AYLESTONE exchange in leicester. All download is limited to overnight peroid so its not constant downloads.
Has anyone else been experiencing similar issues?
No, I'm also LLU on the Wolverton exchange.
I'm not using the line, so it's equivalent to a no d/l situation.
We've not had anything similar reported, without your explanation the graph looks like a heavily used connection i.e. P2P/streaming. I think if this is not the case you need to check with support or perhaps the Be* forums re the status of your local exchange.
Are you using a Thomson router by any chance?
AzShane
No netgear DGND3300v2, and the connection is shared so i'll give it a go tomorrow without other people on it.
AzShane
Sorry for double post, But it turns out the problem was with the new lodger... isolated him from the router and perfect. seems he is constantly uploading somthing :P Thanks for the replies though!
NP  :thumb: At least now you can enjoy your connection must have been very laggy before.
AzShane
Yes very :), back to the awesome connection that it always has been!  ;D
