Firefox toolbar removal
Started by Broadback, Dec 19, 2011, 11:41:59
Broadback
I was looking for software to conver tpdf files to and from wps files, the software I downloaded (yes I am a sill billy) put a tool bar on my firefox, which I do not want. To add insult to injury the program does not do what I want. Is there an easy way to remove the toolbar, I do not want to reload Firefox as I have it just the way I like it?
Click on the Firefox button at the top left of the FF window then select 'Add ons' from the menu that appears this will load the 'Add ons Manager' window, select 'Extensions' from the left hand menu and you should find the toolbar listed in the main window with a button to remove it.
Broadback
Like Magic, many thanks Ray.
