ROUTER LOG-IN
Started by Christopher, Jan 11, 2012, 20:22:03
Christopher
Hi,a belated happy new year to you all. Just a quickie,when I want to access my router should I enter my own IP address or 192.168.0.1 or does it not matter which?
Regards
Chris
Thanks and you need to use the router address.
You can also type www.routerlogin.com into your browser's address bar.
Does that not only work on certain brands, Mitch?
It takes me to Netgear support.
Christopher
Regards
Chris
Quote from: Steve on Jan 11, 2012, 23:07:25
Same here and I don't even own a Netgear router  ;D
It only works on the LAN side of a Netgear router, so if you are connected to one of its ethernet LAN ports, never tested it on wireless.
I can confirm it works on the wireless side on Netgear routers too.
