iPhone cache flush
Started by Simon, Jan 17, 2012, 21:08:29
Is there any way to flush the DNS cache on an iPhone?  I get the same problem at times.  Very slow loading of websites on the iPhone, but using the PC, they come up like lightning.
You can reset the network settings but not sure whether that will help, you can also clear the history and data cache in Safari.
Quote from: Simon on Jan 17, 2012, 21:08:29
Settings>general>reset>reset network settings
This will flush the cache but will will have to reconnect the phone to your network once it reboots.
Is it possible to get into terminal on an iPhone?
Just curious
Only with a jailbreak.
