Is upgrade to adsl2+ working?
Started by zipp37, Jan 07, 2012, 15:05:45
Yes you would. Worse, you'd not get told anything at all. You'd call, and what answer would you get? "Reset your hub"? (I've been there with O2, not sure if BT are the same, but I'd assume so.)
zipp37
It seems like the switch finally got turned on ;D
Router: Netgear DGN2200
connection speed:  downstream 12278 kbps, Upstream 440 kbps
line attenuation: downstream 38.0 db, upstream 15.4 db
noise margin: downstream 6.2 db, upstream 26.8 db
Speedtester results: Download speedachieved during the test was - 8168 Kbps
                            For your connection, the acceptable range of speeds is 4000-21000 Kbps.
                            Additional Information: Your DSL Connection Rate :12278 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
                            IP Profile for your line is - 10832 Kbps
                            Upload speed achieved during the test was - 364 Kbps
                            Additional Information: Upstream Rate IP profile on your line is - 440 Kbps
Curious why upload is only 440 and why the max speed during test was only 8168? Is this because the line needs to resync?
Throughput is not too far from IP profile, I think you need to check at various times of the day as congestion may be playing apart. The upstream sync I would speak to support, they may be able to tell you how and why your line was configured in that fashion. It maybe to achieve the downstream sync they've had to back off on the upstream. :dunno:
It's progress though.
MisterW
QuoteCurious why upload is only 440
I would guess you've got a capped upstream profile. Unless you do a lot of uploading I would stick with that, as uncapping the upstream can sometimes reduce the downstream.
Steve is right on the speed, its not far from your profile and I'd look at it at various times.
zipp37
connection speed:  downstream 9296 kbps, Upstream 444 kbps
line attenuation: downstream 38.0 db, upstream 15.5 db
noise margin: downstream 12.3 db, upstream 26.5 db
Every day at 12.50pm my modem resyncs the connection speed drops and the noise margin rises!
Anyone know why this is? Everything seemed stable otherwise.
If it's the same time everyday it would be worth looking for some electrical equipment in the house that turned off/on at that time.
