what the hell....
Started by magicman, Feb 13, 2012, 16:52:02
magicman
Here are some stats from yesterday
Data Rate Up Stream 448 (Kbps.)
Down Stream 6620 (Kbps.)
Noise Margin
Upstream 26 dB
Downstream 15 dB
Attenuation
Upstream 25 dB
Downstream 22 dB
and this is today
Data Rate Up Stream 1274 (Kbps.)
Down Stream 13769 (Kbps.)
Noise Margin
Upstream 7 dB
Downstream 5 dB
Attenuation
Upstream 12 dB
Downstream 25 dB
My phoneline went down this morning so god knows what has happened, i'm not complaining tho
Looks like you have been moved to ADSL 2+ or LLU, will a BT speedtest run?
esh
Yep, that's ADSL2+/LLU. I had almost exactly the same stats to you before *and* after.
magicman
for some reason the btspeedtester only gave me the speed
1. Best Effort Test:
Download Speed : 11 Mbps
2. Upstream Test:
Upload Speed : 1.08 Mbps
As the BT speedtest ran, I believe you are on an ADSL2+ connection now.
magicman
i know bt have been doing a bit of work in the area this past week, probably due to the fact that fttc is supposed to be going live at the end of march
Niall
Oddly, my connection has been fixed for about 3 weeks. I come home today and suddenly I'm back to a 6mb line. What the friggin hell is going on with my shite connection? So fed up with it being random :( I've lost 6mb overnight.
Flickr Deviant art
Leo Tolstoy
cleopatra2007
i also have been having these problems since yesterday, support staff say..
no problem logged by BT. would also like to know what's going on!!!
Download speed achieved during the test was - 309 Kbps
For your connection, the acceptable range of speeds  is 600 Kbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :7.81 Mbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
Niall
My upload speed has halved too. AWESOME.
Flickr Deviant art
Leo Tolstoy
