Replacement BT modems
Started by ukwiz, Apr 17, 2012, 12:20:22
ukwiz
Several months ago BT started to replace the FTTC modems due to initial bad manufacturing. This was supposed to be rolled out across all FTTC customers, wasn't it?
I have neither seen nor heard anything from IDNet about this.
Does anyone know what is supposed to happen?
What revision modem do you have at the moment?
ukwiz
Would that be the big 3B on the bottom?
That's it yes and that revision is fine so won't requiring exchanging.
ukwiz
