delete folder
Started by Baz, Apr 22, 2012, 10:03:40
im un installing malwarebytes to re install it as I have started to get problems with it freezing.
it un installed ok from the malwarebytes uninstaller prog but I tried to delete the folder it left and it wont play fair, just got error window saying is disc full or program in use.
checked the folder properties and its ticked as read only, when I change this I get the are you sure question then ok but it just re ticks the box so not allowing me to delete it
any ideas
thanks
Reboot and then try deleting the folder.
tried that Simon and still same.Malwarebytes uninstall needed an auto re boot to complete but I have also tried it after with no luck
theres only 1 file left in the folder, a .dll file
Have you tried deleting the file first and then the folder, Baz? that's worked for me in the past when I've had that problem.
Failing which, try booting into safe mode, Baz.
If that doesn't work there are a series of commands you can run that will allow you to take control of the file/directory and remove it but they are not easy to explain. Ultimately, if nothing else works, there are many utilities that usually do work either directly or after a reboot. http://lockhunter.com/ is one of them.
Quote from: Glenn on Apr 22, 2012, 11:23:53
http://www.malwarebytes.org/mbam-clean.exe should do it.
thats got it    thanks Glenn  karma on the way  :thumb:
and thanks for all the other tips
