Word 2010
Started by Den, Sep 04, 2012, 19:46:09
Den
Today I received two emails from two different sources both containing attachments in word. On both when I try to open them it tells me I have not got word installed. If I save them as a document and then try to open them it works OK but not directly from Outlook. Any thoughts as I'm stumped?
Mr Music Man.
http://www.microsoft.com/en-us/download/details.aspx?id=3
If it's an issue with document versions that download caters for most permutations I think.
I take it you mean open them through Word Den?
If so then its a file association issue, the quickest way to fix it is this (Note this may reset a few things in Word):
Press the Windows key and R
Type winword /register and click OK
Word will start briefly and then close but it will have reregistered itself with the system including file associations.
