Idnet email server settings on Samsung Galaxy S3
Started by benga, Oct 14, 2012, 19:43:52
benga
Hi,
Does anyone know the idnet email server settings on the Galaxy S3, in this case as relayed through Orange?
I'm being asked for a port number for the incoming on pop3.idnet.com as well as a port number on the outgoing smtp.orange.net
Also, what security settings should I apply if any?
I'd be thankful for any help.
Ben
 :welc5: :karma:
Hi Ben
These settings work with mobile devices;
In: imap.idnet.com
User Name: xxxxx
Password: xxxxxx
Out: smtp.idnet.com
SSL: Off
Authentication: Password
Server Port: 587
 :welc5: :karma:
These are the standard 'generic' mail port settings.
Incoming Connections
IMAP, non-SSL: 143
IMAP, SSL: 993
POP, non-SSL: 110
POP, SSL: 995
Outgoing SMTP Connections
SSL: 465 (or 587)
non-SSL: 25
My Mac picks up SSL for my IDNet Domain on port 110 :dunno:
peasblossom
benga
Hi Glen,
That seems to have done the trick! Thanks so much for that - and to all you other guys who posted on the problem.
Ben
Thanks for the update, glad it worked for you.
