Traceroute
Started by Polchraine, Nov 13, 2012, 12:29:45
Polchraine
I am trying to sort out some problems that members of another forum are having and need to gather some traceroute information from various ISPs.
Please could I ask if members here could run a traceroute for me and then either PM the results through to me, or add them to the thread.    Please remove the IP address from the first two hops - which would correspond to your local network and public IP, replacing them with rrr.rrr.rrr.rrr
The destination is     www.full-bore.co.uk
  1     *        *        *     Request timed out.
  2    13 ms    12 ms    12 ms  10.0.0.1
  3    12 ms    12 ms    13 ms  192.168.201.90
  4    13 ms    13 ms    12 ms  192.168.134.2
  5    12 ms    12 ms    12 ms  192.168.71.13
  6    13 ms    15 ms    13 ms  192.168.69.252
  7    13 ms    12 ms    12 ms  217.39.0.2
  8    13 ms    13 ms    13 ms  213.120.178.41
  9    13 ms    13 ms    15 ms  acc2-10GigE-0-0-0-0.l-far.21cn-ipp.bt.net [109.159.249.120]
10    21 ms    13 ms    15 ms  core1-te0-7-0-4.faraday.ukcore.bt.net [109.159.249.33]
11    13 ms    13 ms    13 ms  peer2-xe8-1-0.telehouse.ukcore.bt.net [109.159.255.101]
12    13 ms    13 ms    13 ms  195.99.126.129
13    14 ms    14 ms    14 ms  iomart.londra32.lon.seabone.net [89.221.43.106]
14    14 ms    15 ms    14 ms  593.net1.north.dc5.as20860.net [62.233.127.174]
15    15 ms    16 ms    15 ms  87.117.211.46
16    16 ms    15 ms    15 ms  cpanel.full-bore.co.uk [5.77.45.227]
The first look a little odd as I am using an Openzone hotspot and the 192.168.xxx.xxx are in a local network before breakout.
Traceroute has started...
traceroute to full-bore.co.uk (5.77.45.227), 64 hops max, 72 byte packets
1  home.gateway.home.gateway (192.168.1.254)  1.816 ms  1.718 ms  1.643 ms
telehouse-gw4-lo1.idnet.net (212.69.63.98)  17.588 ms  17.810 ms  20.181 ms
telehouse-gw6-gi3-401.idnet.net (212.69.63.182)  18.532 ms  17.884 ms  16.885 ms
te8-4.core1.thn.as20860.net (195.66.224.207)  17.750 ms  17.442 ms  19.142 ms
593.net1.north.dc5.as20860.net (62.233.127.174)  20.122 ms  18.546 ms  18.404 ms
6  87.117.211.46 (87.117.211.46)  19.103 ms  33.141 ms  18.299 ms
cpanel.full-bore.co.uk (5.77.45.227)  18.833 ms  19.591 ms  22.112 ms
I would try from work, but it's timing out after the 3rd hop. There are ongoing proxy issues here this week.
From our office connection (Timico)
  3     2 ms     1 ms     1 ms  ip-rrrrrrr.dsl.twang.net [rr.rr.rr.rr]  (oooh arrrr)
  4    26 ms    33 ms    26 ms  lo5.the-lns2.router.timico.net [62.121.9.205]
  5    95 ms    45 ms    27 ms  vl917.tch-edge2.uk.timico.net [62.121.12.22]
  6    26 ms    26 ms   100 ms  te8-4.core1.thn.as20860.net [195.66.224.207]
  7    98 ms    27 ms    27 ms  593.net1.north.dc5.as20860.net [62.233.127.174]
  8    28 ms    29 ms    28 ms  87.117.211.46
  9    29 ms    27 ms    27 ms  cpanel.full-bore.co.uk [5.77.45.227]
For what it's worth the same connection to my home (IDNet) connection is:
  4    26 ms    27 ms    30 ms  lo5.the-lns2.router.timico.net [62.121.9.205]
  5    45 ms    26 ms    27 ms  vl917.tch-edge2.uk.timico.net [62.121.12.22]
  6    26 ms    26 ms    26 ms  idnet-gw-a.lonap.net [193.203.5.132]
  7    27 ms    27 ms    26 ms  telehouse-gw4-gi0-1-400.idnet.net [212.69.63.244]
  8    37 ms    38 ms    37 ms  rrrrrr.me.uk [rr.rr.rr.rr]
JB
Tracing route to full-bore.co.uk [5.77.45.227]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  nnn.nnn.nnn.nnn
  2    12 ms    11 ms    12 ms  losubs.subs.dsl2.wh-man.zen.net.uk [62.3.87.147]
  3    12 ms    11 ms    11 ms  xe-0-3-0-115.cr2.wh-man.zen.net.uk [62.3.87.185]
  4    15 ms    13 ms    14 ms  ge-3-0-0-0.cr1.kp-leeds.zen.net.uk [62.3.80.58]
  5    17 ms    15 ms    13 ms  ge-3-1-0-0.cr2.kp-leeds.zen.net.uk [62.3.80.74]
  6    19 ms    19 ms    19 ms  ge-3-0-0-0.cr1.th-lon.zen.net.uk [62.3.80.78]
  7    19 ms    77 ms    18 ms  ge-2-0-0-0.cr2.th-lon.zen.net.uk [62.3.80.42]
  8    18 ms    18 ms    19 ms  te8-4.core1.thn.as20860.net [195.66.224.207]
  9    19 ms    20 ms    20 ms  593.net1.north.dc5.as20860.net [62.233.127.174]
10    21 ms    20 ms    20 ms  87.117.211.46
11    20 ms    19 ms    21 ms  cpanel.full-bore.co.uk [5.77.45.227]
Trace complete.
JB
From home:
  2    11 ms    11 ms    12 ms  telehouse-gw4-lo1.idnet.net [212.69.63.98]
  3    11 ms    11 ms    11 ms  telehouse-gw6-gi4-400.idnet.net [212.69.63.246]
  4    99 ms    30 ms    48 ms  te8-4.core1.thn.as20860.net [195.66.224.207]
  5    12 ms    12 ms    13 ms  593.net1.north.dc5.as20860.net [62.233.127.174]
  6    13 ms    13 ms    13 ms  87.117.211.46
  7    13 ms    12 ms    13 ms  cpanel.full-bore.co.uk [5.77.45.227]
armadillo
From home
  1     1 ms    <1 ms    <1 ms  nnn.nnn.nnn.nnn
  2    32 ms    32 ms    31 ms  telehouse-gw4-lo1.idnet.net [nnn.nnn.nnn.nnn]
  3    30 ms    31 ms    31 ms  telehouse-gw6-gi4-400.idnet.net [212.69.63.246]
  4    31 ms    31 ms    30 ms  te8-4.core1.thn.as20860.net [195.66.224.207]
  5    32 ms    35 ms    36 ms  593.net1.north.dc5.as20860.net [62.233.127.174]
  6    32 ms    32 ms    33 ms  87.117.211.46
  7    32 ms    32 ms    32 ms  cpanel.full-bore.co.uk [5.77.45.227]
2    30 ms    29 ms    29 ms  telehouse-gw3-lo1.idnet.net
3    29 ms    29 ms    29 ms  telehouse-gw6-gi4-400.idnet.net [212.69.63.246]
4    29 ms    29 ms    60 ms  te8-4.core1.thn.as20860.net [195.66.224.207]
5    30 ms    30 ms    30 ms  593.net1.north.dc5.as20860.net [62.233.127.174]
6    31 ms    31 ms    31 ms  87.117.211.46
7    30 ms    30 ms    31 ms  cpanel.full-bore.co.uk [5.77.45.227]
trace complete.
Polchraine
Thanks all of you.   Looks as though none of you had issues.
