Huawei HG612 Stats & Graphing Programs for VDSL2 (FTTC) Windows Users
Started by Bald_Eagle1, Mar 02, 2013, 22:50:15
Bald_Eagle1
A small package of connection statistics logging/graphing programs has been recently devoloped from the original batch file script versions.
These programs are more robust than the scripted versions and are much quicker in use to boot.
Thanks to RONSKI's efforts, everything can now be set up using a GUI settings editor for fully automated data harvesting & graphing via user-defined scheduled events.
.Net does need to be installed to make full use of RONSKI's settings editor.
.Net version 4 has been used for extensive testing of the programs on systems ranging from XP Home Edition to Windows 7 & related Home Server versions.
However, users can still manually edit a text based configuration ini file if choosing not to install .Net
AFAIK, .Net was already included with Windows versions starting with Vista, so installing it is probably only relevant for the few XP users who don't already have it installed.
Resyncs are now detected (if monitoring 24/7) & the data is immediately logged, along with optional graphing.
The mis-reported FEC/CRC errors issue from the HG612's own buggy GUI has also been dealt with.
The output is almost identical to later scripted versions, just that there is more of it to assist with trouble-shooting problematic connections.
Once a reliable download site has been chosen, I'll post links here accordingly, so watch this space  ;)
At some stage in the not too distant future, these programs are also likely to be converted back to their Linux and ADSL roots as originally developed by Burakkucat, along with asbokid's input.
Ronski
Hi all, I'm Ronski and for the past two months or so I've been developing the settings editor to set up Bald_Eagles excellent updated logging programs, along with testing them.
To do this I've had to learn VB.Net, and I haven't really programmed since I was a teenager, about 30 years ago.
So take it easy if you find anything not quite right, but please do let us know.
We'll update the thread once the download is available.
Bald_Eagle1
Quote from: Glenn on Mar 03, 2013, 08:22:09
Is there a link for the download anywhere?
It's coming soon & will be posted here as soon as it's live.
Ronski
Thanks for the warm welcome  :thumb:
Download is now live at Freewarefiles.com, I'm sure the Eagle will be along soon to update the first post.
Edit: If upgrading to the new version don't forget to backup any logs/graphs just in case. In my experience it is perfectly fine to keep your modem log file, I'm still using the same one I started last August.
Also if you like it then please rate it and leave a review on Freeware files, if you have any problems then let us know.
Ronski
Just to let everyone know that the editor requires dot.net version 4, or else it won't run.
Bald_Eagle1
The first public revision to the HG612 Modem Stats package has now been released.
It is available here:-
http://www.freewarefiles.com/HG612-Modem-Stats_program_84567.html
Click the Blue Download Now! button & choose one of the Download Mirrors.
It is still currently aimed only at VDSL2/FTTC connections for Microsoft Windows users, but an ADSL version is on its way, combined with Linux compatibility.
The package has been fully tested on XP, Vista & Windows 7 systems & although not perfect, some increased compatibility with problematic Windows 8's Task Scheduler has been built in.
What´s New in version 1.1:
• Connection Up time & Total Bits loaded reported in the Bitloading graph.
• Bitswap graphs per tone in the Ongoing graphing
• Auto-reset the modem´s internal clock at each resync
• More efficient/quicker harvesting/logging, especially for larger modem_stats.log files (mines now 202 MB (212,705,280 bytes) in size).
• Ability to disable extensive event/error logging, just reporting the basics and any true errors (keeps the log file size down).
• Separate resync log.
• Ability to use a different task name.
• The programs should now be fully compatible with the HG610, HG612 & HG622 modems.
• Other various tweaks we can´t remember :-)
New users should simply extract the contents of the zip file to Drive C:, ensuring "Expand Folders" or similar setting is selected for a default setup.
Existing users of the initial version 1.0 should extract all the files & subfolders to the relevant existing folders to ensure the slightly different operation of the package is picked up.
Once all the files are in place, existing users should delete the original HG612 Stats Program task & create a new one via the Settings Editor.
By default, Current (snapshot) data will be harvested & plotted every 8 hours, starting at 06:00 & Ongoing data will be harvested every minute, being plotted at 06:00 each day.
These settings can be easily adjusted or logging and/or automated graphing turned off via the Settings Editor.
