Failing to receive email notification when my posts are repliedto
Started by Broadback, Aug 27, 2013, 15:13:34
Broadback
The title says it all. I have checked the email address and notification is on, at first I thought is was a problem I was having with my computer, but now I think not. I have sent myself an email to the address in question, that arrived OK. all suggestions welcomed.
I'll check to see if there's a problem with the forum. Is anyone else experiencing any problems with notifications?
We've had this before, and usually, if it were a problem with the forum, it would also be afftecting other users, and no one else has reported an issue to my knowledge, BB.  It's often a browser / cookie issue so I would suggest you untick the notifications box, log out of the forum, clear your cache and cookies, reboot the machine, then log back in and reset your notification settings, also making sure that the forum cookie is not being blocked from being saved in your browser.
In the meantime, as Zap said, we will check things this end.
Quote from: zappaDPJ on Aug 27, 2013, 16:27:10
Yes, me.
No reply or new topic notifications, and tried logging out and back in again, and restarting the browser.
Not convenient to reboot the Mac atm.
We're still investigating, but it does seem as though there is an issue with the forum sending out emails.  If it's server related, we may have to wait until IDNet can sort it tomorrow.
tehidyman
Yes, me
Broadback
Thanks for the info. so at the moment I will wait and see before I start messing with cookies etc.
Thanks for the confirmations, this is still being looked at but we hope there will be a fix for it sometime today.
Broadback
I agree, I received on another thread I'm subscribed to.
