router logs
Started by Baz, Mar 10, 2014, 19:22:21
Ive noticed some entries in my router log over the past few nights and last week too that I just cant find what the address is.
[DHCP IP: (xxx.xxx.xx.xx)] to MAC address 00:03:78:BC:19:E3 Monday, March 10,2014 03:00:56
I have access list set up on the router so only things I want can get in, so I thought,which is printer/laptops/phones when needed/PS3/PS4, but this is wired through a switch and thats all I can think of.This MAC address is not in the access list and it shows 3 entries in the log just a few seconds apart usually early morning each time.
Router is Netgear DGN3700v2
Hmmm   yeah two Foxsat HDR.
Could it be that?   they do check for update software but its OTA (over the air ) isnt it?
According to that link, the MAC's are in the Humax allocated range, are they networked?
Just had a quick look at the set in my sons room upstairs and it is cabled through a switch for i player and the like....could be that yeah.I'll try it out and see what happens Thanks Glenn  :thumb:
