Idnet website not accessible?
Started by Ray, Aug 20, 2014, 12:15:10
Quote from: Simon on Aug 22, 2014, 00:10:04
Changing energy suppliers is something I should be looking at too.
Depending on you usage some of the smaller ones are really good like Ecotricty and Good Energy. I stayed with Southern Electricity as the saving was only £25 over a year and I get the warm home discount with SSE whereas some smaller companies don't do that. Also I had smart meters fitted which make life a lot easier and I can see in real time my usage (sent every 30 mins) and help keep it as low as possible. (Also I cant get to gas meter as its to low to bend down to so this saves on estimates)
Perhaps I'm being naive, but I find myself hesitant to look at the smaller companies.  Would support be as good in the event of a power failure (ie, would a fix be as quick), and what would happen if the company suddenly went bust?  How easy would it then be to transfer to another supplier?
Clive
Quote from: Simon on Aug 21, 2014, 22:10:11
You're still on one of the old packages, Clive.  The difference is that the 25Gb on Enterprise Lite is not split peak / off peak, so, whereas you currently have 40Gb split, but can only use 30Gb of it off peak, with the new package, you'd get 25Gb to use whenever you like.  :)
Sorry guys, but I've logged in to upgrade to Enterprise Lite but it says something about having to pay a charge to upgrade from ADSL to ADSL2.  I haven't a clue what ADSL2 is or if I will need new equipment.  It's telling me I'll get 18Mp/s download speed but I know I'm only getting 6.5 Mp/s at present.  Can anyone enlighten me?   :D
I think you will automatically get upgraded to ADSL2+, hence the increase in line speed, but you shouldn't get charged as it's still only a package upgrade.
Give them a quick call to put your mind at rest, Clive.  :)
Quote from: Simon on Aug 22, 2014, 14:31:43
I remember paying a one off £11 to go from adsl to ADSL2+ as its a different product not sure of they still charge that. Depends on your router Clive most routers can do ADSL2+ but worth checking.
As Gary said, I thought there was a nominal charge?  ( but may be no longer applicable) However the adsl2+ estimate looks a worthwhile upgrade in terms of speed, you may however use more bandwidth with a faster connection.
I'm fairly certain that I wasn't charged for my upgrade.  It will be interesting to see what they tell Clive.
I was adsl and adsl2+ are two different products its not a package change and im sure involves BTW/BTOR doing some magic with some buttons. It may have changed by now though.
I haven't read all through this, but it might throw some light on the upgrade charge:
http://www.idnetters.co.uk/forums/index.php/topic,29721.0
Clive
Or not as the case may be.   ;D  OK, I'll have to phone them and hope I get someone who understands it.   :whistle:
Clive
I think perhaps the reason I wasn't charged, is that I pay annually.
Clive
They want me to e-mail them.
Clive
 :laugh:  Nick mailed me back to say it's an upgrade to adsl2 for which there is a charge of £11 + vat.  It will take one working day and my Netgear will probably still work if a setting is changed.  Obviously I'll wait until after the bank holiday now.
Well, you could do it through the portal and presumably it won't happen until Tuesday anyway - but perhaps best to wait until someone is there, just in case.  :whistle:
I just wonder if an email request is just to provide proof in case of misunderstanding.
Clive
Good point, but I'd pressed 1 for sales and got through to support instead.  Support said they would get sales to phone me back but they were too busy so support asked me to send an e-mail.  I'm just happy they are so easy to contact.   8-)
