broadband usage
Started by Broadback, Sep 27, 2014, 14:25:40
Broadback
Since last logging into IDnet they have revamp their web page. I cannot see how I find my usage any more, I'm sure it is there somewhere, but I cannot see!  :(
Clive
It's on the Dashboard but you haven't scrolled down far enough.  When you reach Broadband, you will see it to the right of the phone number you are using for it.  :)
Broadback
I still cannot see it. All the details of my phone package are there but little information about my broadband, certainly I can find not usage. Obviously I am acting dim, no bit surprise!
Clive
Strange.  What I have is as follows:
Broadand
ID           Telephone           Username                    Package
50461   016567****   016567****@idnet   R Home Plus (ADSL2+)   View Details View Usage Upgrade Package
You'll probably have to phone support. I had what sounds to be the same issue and the reason I couldn't find my usage is that it wasn't there to find. It had to be added.
Broadback
#5
Where as I have:
41xxx    01782 3*****   jc@ *****
Nothing under package at all.
Perhaps I should contact the help desk.
Thanks for your help Clive.
Seems like I need to, thanks Zappa
Broadback
Whoops, finger trouble,I washed my hands to day and cannot do a thing with them! the 8's should be *'.
