Windows 8, a new annoying Popup
Started by Broadback, Feb 06, 2015, 10:31:54
Broadback
In the last couple of days I have been getting a popup headed "Information from computer26oct14(E:) with "Drive Tools" highlighted in green. Is windows trying to tell me something or is it rubbish, in which case how can I prevent it happening?
Sounds like malware or virus to me.
Can you provide a screenshot of the popup, providing it doesn't reveal any personal information?
Broadback
I will try the next time it pops up.  :eek4:
It certainly sounds like malware but it's not something I've come across before. A screen shot would certainly help.
Clive
You might consider downloading Malwarebytes and running a scan.  If it finds anything it will remove it for you.
https://www.malwarebytes.org/mwb-download/
