Usage on Dashboard?
Started by tfw7, Apr 17, 2016, 15:21:28
tfw7
Is it just me, or has the "check your usage" thingy gone from the dashboard? Some time in last couple of weeks maybe?
Mine is still there. If yours has gone a quick call to support should get it fixed :)
Clive
Mine also.
Home Lite (ADSL MAX)    View Details   View Notifications   View Usage   Upgrade Package
tfw7
Thanks. mine is still missing! Will give support a call like you say, cheers
tfw7
just to update in case anyone else has this issue:
emailed support, SimonM has sorted it, usage now showing - cheers!
Clive
