NEW FTTP USER
Started by ReDGryphoN, May 08, 2016, 19:48:10
ReDGryphoN
Hi All,
Having suffered with 2.5MB for over a decade and having waited 16 months from order  for the FTTP to come to my house. last Friday it happened.
I have opted for the 80MB pro package from IDNET
My question is this, what download speed should I be receiving as I am not getting above 40? and the variability in the speed is unbelievable.
Is there a training process for this or as it is an optical line direct to the house is this not needed?
I have been measuring the speeds constantly both wired and wireless and have yet to see it go over 40 and have seen it as low as 7?
Any ideas about this or what I should be doing about it?
I am using the Billion 8800NL supplied by IDNET
Regards
ReD
BILLION 8800NL USER FTTP
Henry David Thoreau
Den
I'm sorry but I left idnet and moved to BT Infinity and get a constant 72MB. I wonder if it's the BT router that holds the line so well.
Mr Music Man.
He's no line Den , if it's FTTP it's fibre optic cable to the premises.
I know nothing about FTTP but I thought 330/30Mbps was the theoretical advertised speed? 80Mbps down sounds more like FTTC and I would certainly expect to get consistently a lot more than 40Mbps. If it's going as long as 7Mbps I'd say you have a problem regardless of any line training period. Probably best to give support a call tomorrow morning :)
zap, the FTTP packages are shown here: http://www.idnet.net/data_products/fttp.php so whilst yes it tops out at 330 the 80/20 package is also available (and is the lowest I believe on FTTP that BTW offer).
I wonder if a setting somewhere is wrong. Take a look at this example from plusnet: https://community.plus.net/t5/Fibre-To-The-Premises-trial/FTTP-Speed/m-p/1073062
Quote from: Lance on May 08, 2016, 22:30:32
Thanks Lance, I didn't know IDNet were offering FTTP to be honest.
ReDGryphoN
Thanks for the replies,
I will contact IDNET today and get them to check which package I am just to be sure the package is in fact FTTP
No change on the download but upload is fairly constant at 20
ReD
Henry David Thoreau
