idnet e mail
Started by talos, Oct 20, 2022, 07:53:42
talos
how do I empty my deleted posts file , idnet tell me its full, but I can't find a way to empty it?  :dunno:
I think you'll need to login to webmail, Bob, or use an email client set up on IMAP to sync with the Deleted Items folder, then you can clear them.
https://webmail.idnet.com/
talos
Thanks Simon
                          It was pretty simple really, just having a senior moment I hope :thumb:
