Checking router setting
Started by browney, Jul 28, 2006, 10:50:54
browney
I moved to IDNet for the low game pings but it seems there just the same
Simon said
You router will be able to tell you if it sees that connection as "fast
Path" or "interleaved" in its connection stats.
But I can't find this setting any were my router is the NETGEAR DG834Gv2
Gilba
Hi there,
If you look at this post it will tell you the instructions on how to find the details of you connection.
If you still don't know post what is shown on the page and we will be able to tell you.
browney
Just found one
First logon to the router and then select this address:
http://192.168.0.1/setup.cgi?todo=debug
which should result in a screen which just says 'Debug enable'.
(That's assuming that you haven't changed the router's IP address from the default).
Then exit from the web interface and open a command-line window. Type:
telnet 192.168.0.1
You should get a BusyBox welcome message to confirm that your telnet connection is established.
Now type:
cat /proc/avalanche/avsar_modem_stats
Jeff
