Ok, I've fixed it what happens next?
Started by Bat, Oct 21, 2007, 14:14:44
I'm intrigued now, let me know what your stats are tomorrow will you?
Bat
Hi,
Sure. I've got goldfish memory so I'll be lucky if I can remember to switch it off and back on again! :o
Cheers,
Gavin :)
I can send you a time switch if you like. :)
Bat
Hi,
Now there's a good idea! I'd leave it on for a week though! ::)
Cheers,
Gavin :)
Bat
Hi,
Told you I'd forget ::)
Shutdown last night, this morning I'm at:
Uptime: 0 days, 0:05:40
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,864
Data Transferred (Sent/Received) [KB/KB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 31.5 / 39.0
SN Margin (Up/Down) [dB]: 24.0 / 15.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Speak to you later...
Gavin :)
Can you do a BT speed test please, Gavin?
Bat
Hi,
Tah Dah .....
    DSL connection rate: 448 kbps(UP-STREAM)  4864 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 3708 kbps
Current router stats ........
Uptime: 0 days, 11:32:00
SN Margin (Up/Down) [dB]: 24.0 / 13.0
Error Seconds (Local/Remote): 4 / 0
FEC Errors (Up/Down): 0 / 3,698
CRC Errors (Up/Down): 0 / 6
HEC Errors (Up/Down): 0 / 5
Cheers,
Gavin :)
That's fine, Gavin, throughput is good for the profile, profile is right for the sync speed.
If you can manage to keep a stable connection for a couple of weeks, your target noise margin should decrease by 3d, and will repeat until the line becomes unstable. As that happens your sync speed will improve and the profile will follow. It's slow, but we are talking about BT here. :)
Bat
Hi,
At least now it's all heading in the same direction :)
Thanks Ric & Andrew :)
Cheers,
Gavin :)
Bat
It's OK, Gavin, my uncle gets it wrong all the time, and he's known me for a long time! ;)
