malware
Started by alcav, Dec 27, 2007, 16:25:04
alcav
Hi all
does anyone know of a malware remover without having to pay a fortune for yet another application :)
Thanks.....Alan
I would recommend Super AntiSpyware, which comes in Free and Pro flavours.  :)
Quote from: Simon on Dec 27, 2007, 16:49:51
Agreed Simon. ;)
alcav
Hi Guys
thanks for your help,we cured the prob by going into safe mode and running Adaware,seems to have done the job :)
Happy New Year.........Alan
And to you, Alan. :)
Glad to hear it's fixed, Alan.
Noreen
Having ditched Ad-Aware and SpyBot, I've now installed free SUPERAntiSpyware having read good reports elsewhere and here. It takes an long time to do a complete scan of everything, I hope that that just means that it's doing a thorough job. It only found a tracking cookie though. ;D
It does take a while, Noreen, but I usually let scans run while I'm doing something else away from the computer, as often the scan takes up a lot of resources, and if you're battling against it to do other stuff, it makes the scan slower.  :)
Same here Simon, I usually turn off my monitor and let it do it's thing.
Noreen
I won't take such an interest the next time. Just using it for the first time I was interested in what it was doing. ;D Anybody got any advice re any special settings?
The full scan should cover everything, Noreen.  :)  Just make sure the box is ticked in Preferences to automatically check for updates, and as it's the free version, without real-time protection, I would untick all of the Startup options, as you don't really want it starting with Windows, as it won't actually be doing anything unless you launch a scan yourself.  :)
Noreen
Thanks Simon. Now done that.
