On my way to ID...
Started by Si, Jan 25, 2008, 15:12:49
0 Members and 15 Guests are viewing this topic.
And she went on to become a phone... :)
Si
Quote from: Rik on Feb 01, 2008, 16:57:30
In that case wasn't he SIMbu?
For the avoidance of confusion I'm not THAT Simon, or the OTHER Simon. :)
Den
and Flash went on to become a fast running cheese        Gordon Zola
Mr Music Man.
Malc
Or the other days weather    -    Wednesday Hail
Is that like Ruby Tuesday, only different? :)
Malc
RA-1972
Si
Quote from: RA-1972 on Feb 01, 2008, 18:52:28
welcome Si. :)
Thank you! Managed to get a BT speedtest done, confirms my profile is set at 2k at the moment. Hopefully that will sort itself out in the not-too-distant future and then I can get flying... :thup:
It's not uncommon. Hopefully it won't take long for it to clear and you be zooming along. :)
Malc
My first two days were a bit erratic, with a couple of dropped lines, not had a single dip in speed or dropped line in the 3 months since, retraining I suspect
Si
Well, almost exactly 24hr since going live I'm getting the below result....
Now THAT'S what I call broadband! Hopefully at the end of the training it'll still be somewhere near that.
Well done IDNet.
Very nice, Si. Be prepared for that kind of level of speed at all times.  8)
That looks like your profile has lifted to its correct level, Simon. Try for a BT test at some point, that will confirm it.
Congratulations.  ;D
Si
Quote from: Rik on Feb 02, 2008, 13:01:47
Congratulations.  ;D
Looks like it:
"Test1 comprises of Best Effort Test:  -provides background information.
    Actual IP throughput achieved during the test was - 6577 kbps"
I think I can live with that.  ;)
You're going to have to - it doesn't get any better until you get ADSL2.  ;D
It seems more and more people are getting better syncs. Recently there seems to have been quite a few people on here getting max sync. I'm very jealous!!!  :P
Indeed. What I've noticed is attenuation figures don't have to be as low as you might think to achieve full sync. The problem is that we have particularly high attenuation figures!
Increasingly, it seems that anyone with a sub-48db attenuation has a resonable chance of full sync, but after that things go downhill rapidly. Oh for a few miles of copper...
Quote from: Rik on Feb 03, 2008, 09:22:21Oh for a few miles of copper...
Just give a couple of Scots a penny, and tell them to share it!  ;D
Yep, that sums it up well, Rik. I've got a 47dB or so attenuation figure and certainly couldn't get full sync, though low 40s potentially could. Still, I'm reasonable happy with a 4000k profile. :)
