Slow speeds this morning
Started by Ray, Feb 13, 2008, 12:18:42
I was just wondering if anyone else been getting low speeds this morning before I contact support? this is the typical speed I am getting, normally it is over 5500kbps.
Nothing appears to have changed on my line stats and the connection had been up for over 9 days. I have also just tried a restart of my router and this has made no difference.
   Line Stats
Uptime:   0 days, 0:05:00
Modulation:   G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]:   448 / 7,616
Data Transferred (Sent/Received) [KB/MB]:   208.00 / 1.45
Output Power (Up/Down) [dBm]:   11.5 / 19.5
Line Attenuation (Up/Down) [dB]:   16.0 / 27.0
SN Margin (Up/Down) [dB]:   24.0 / 13.0
Vendor ID (Local/Remote):   TMMB /
on a 2500 profile, Ray.
Even better on the London server:
I just posted my stats from earlier today on the ping thread Ray, as usual here.
Well I don't know what caused the problem but it's suddenly shot up to over 5000kbps now  :) I think I sense the hand of BT cocking something up somewhere.  :o
madasahatter
BT have a nasty habit of doing that. The number of times that I have contacted them for our clients, and they deny that anything is worng, yet suddenly it all comes right again...... >:D
Could be a hangover from their maintenance work, I guess, or just a fault on the network.
