Oh no, its another slow connection thread :)
Started by k3v, Feb 20, 2008, 18:57:53
Indeed, Lance, which is why I think this may be one for BT, given that he's tried a different filter, router, and socket.  :(
k3v
DSL Connection Details
DSL Line (Wire Pair):       Line 1 (inner pair)
Protocol:       G.DMT
Downstream Rate:       5152 kbps
Upstream Rate:       448 kbps
Channel:       Interleaved
Current Noise Margin:       14.5 dB (Downstream), 20.0 dB (Upstream)
Current Attenuation:       21.5 dB (Downstream), 17.5 dB (Upstream)
Current Output Power:       19.5 dB (Downstream), 12.0 dB (Upstream)
DSLAM Vendor Information:       Country: {B5} Vendor: {TSTC} Specific: {0}
the above is plugged into the master with my old 2 wire router, the line is quiet! no noises.... but i bet it doesnt stay like this!! It seems weird that the attenuation is shown as a lot lower on my  2wire old router as opposed to my 2 wire new (2700 hgv)
Ive had enough today, im gonna leave it as it is for a while and see
once again, thanks for everyones help...
There's certainly something strange going on, Kev, and I just can't put my finger on it!
Let's see if it is stable like that then. I hate these sort of problems which are so difficult to solve!
k3v
 991 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is *****, your browser is reported as being Microsoft Internet Explorer 7.0 and is running on Windows NT 6.0.
BT would regard the speed ranges shown below as normal service:
        ^nice
speedy!
has anyone tried the BT test today, i dont get to put my username in, it just gives me a speed test...
Is there any software to monitor synch/line stats etc
There is an esoteric line fault which can dor that, something to do with high resistance, iirc.
Quote from: k3v on Feb 21, 2008, 21:14:36
There is a program called routerstats available from here: http://www.vwlowen.co.uk/internet/files.htm
You may just wish to use the lite version.
