PING
Started by RA-1972, Mar 06, 2008, 22:32:30
No, the ethernet cable would have an effect, but I doubt it could be measured with anything less than an atomic clock.
It looks like you have interleaving on to me, did IDNet say?
RA-1972
Nope off .
Software Version: 1.09
ADSL Version: 6.0.2.0
Boot Code Version: 0.01
MAC Address: 00-1C-10-00-EB-35
DSL Status
  DSL Status: UP
DSL Modulation Mode: Auto
DSL Path Mode: FAST
Downstream Rate: 8128 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 11 db
Upstream Margin: 25 db
Downstream Line Attenuation: 21
Upstream Line Attenuation: 24
Downstream Transmit Power: 19
Upstream Transmit Power: 11
LOS Errors: 0
Odd that. It seems that first hop is the worst. What happens if you just ping idnet?
RA-1972
C:\Documents and Settings\>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=42ms TTL=59
Reply from 212.69.36.10: bytes=32 time=43ms TTL=59
Reply from 212.69.36.10: bytes=32 time=40ms TTL=59
    Minimum = 40ms, Maximum = 43ms, Average = 41ms
It does look like a BT issue, then. :(
RA-1972
Do you think if ask idnet for diff IP would that make any difference ?
RA-1972
You reply to quick . :rant2:
I doubt it, that shouldn't affect your routing. Ask them though, if they think it would help.
Sorry, can't help the speed - it's the only way I can keep on top of the forum. :)
RA-1972
I have reset my router and pings have dropped by 10 ms , so might give my router a night off and see if it gets any better .
C:\Documents and Settings\nathan stone>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=33ms TTL=59
Reply from 212.69.36.10: bytes=32 time=34ms TTL=59
    Minimum = 33ms, Maximum = 34ms, Average = 33ms
paulsmith109
Maintain router synch. Just keep disconnecting/reconnecting PPP session, checking ping results after each reconnection, and see if anything changes. My wife managed to turn off my router yesterday. It resynched OK of course but pings to idnet had increased to 22ms. I `ve just changed PPP session and on the third change my pings had returned to 11ms.
Give it a try!
