security alert on router ?
Started by David, Mar 14, 2008, 10:34:19
David
Should I be worried set up my router yesterday this morning get a security message should I be worried,when it was set up before I didn't tick the alerts so no alarm bells just yet,any thoughts?
Have a minor issue with Norton as well .
This is really the first ever place I have joined a forum so dont like to post too many questions,feels strange to ask,if this makes sense :fingers:
somanyholes
Hey Bad
What was the message you got?
Don't worry about asking questions, David; we're all here to help each other. :)
What was the security message? Was it in the log?
What's your issue with Norton?
David
udp packet source 212.58.227.80.8458 destination 91.135.6.94.6970 dos.
That's just the firewall doing its job; nothing to worry about. You're not being targeted specifically.
And Norton?
somanyholes
http://www.iptools.com/dnstools.php?tool=ipwhois&user_data=212.58.227.80&submit=Go is where the dos was coming from, it's the bbc as you can see. What gave you the alert? I.e your router etc, have you had any further alerts? Where you using any bbc services at the time?
David
Quote from: Sebby on Mar 14, 2008, 10:38:10
thanks when I was loading the modem yesterday I got a message that there is a Norton remnant in my system and I was wondering if I can download the removal tool and use that without adverse effect on my pc.my other machines are ok but this one the removal tool was not used just removed it manually,if that makes sense
Which version? And is it pure antivirus or another product?
David
Quote from: somanyholes on Mar 14, 2008, 10:46:08
No further alerts :thumb:
David
Quote from: Sebby on Mar 14, 2008, 10:47:47
Which version? And is it pure antivirus or another product?Im not sure I just downloaded from my isp,sorry ex isp (hee hee) it was just Norton security 2007
Hi David
As people have said, thanks guys  :thumb: , it sounds just like the firewall is doing it's job. As to Norton, it would be worth running the removal tool, if that doesn't help, get back to us and we'll do it the 'dirty' way. :)
As to questions, if people didn't post them, I'd have to find something else to do.  ;D
somanyholes
Looks like it was probably a streaming service from the bbc, job done ;)
http://www.robtex.com/dns/rm12.rbsov.bbc.co.uk.html
David
run the  Norton tool and no more trace of it,things just keep getting better thanks again :thumb:
That's good, David. Norton is a real pest to get rid of.
