initial speeds
Started by David, Mar 15, 2008, 15:38:08
David
How do these rate
first time I have pasted,apart from wallpaper in the hall
Download speed looks very good, David, I'll be round to connect. Upload looks slightly low, but I find that is usually the case with that site, certainly nothing to worry about. :)
David
thanks Rik it was in the 9s yesterday
David
3532, Down,
356 up
Cant copy on this (well I dont think so Rik)
David
15th March 2008 16:23:02 360 Kbps 3268 Kbps
15th March 2008 00:16:47 366 Kbps 3532
  yes I can lol :o
Shows just how variable speed testers are, doesn't it. :) Try and do a BT test some time, that's the arbiter.
David
cant ever get past given the phone number on this site
It requires patience, a knowledge of divination and a southerly wind.  8) Best time to try is in the morning, use IE not Firefox, despite what they say.
David
What Rik said. :thumb:
The BT speed tester takes some perseverance (and that's putting it mildly) but it is usually the best indicator of speed.
