2Wire Power Supply Question
Started by LesD, Apr 05, 2008, 13:48:26
LesD
When I received two 2700's from my eBay seller he gifted the second one to me because he had no PSU for it.
I have found a PSU on eBay with the following rating: Rated 5.1 Volts at 2.5Amp (or 4 Amp peak)
Does anyone know if the 2.5Amp current rating is adequate for the Dual SSID version?
Regards,
Les.
Les, my dual SSID 2700 has a psu rated at 5.1 volts DC 3 amps
I would advise you get one that has identical specs to the original, i.e. what Glenn says. :)
g7pkf
i use an ipaq psu for testing.
5v 2amps rating works fine...havent run it for any period of time.
any 5v regulated with at least 3 amps (go for 4 minimum to give 50% overhead-and it will run cooler) should be okay
