More very slow speeds
Started by Dopamine, Mar 31, 2008, 00:45:38
What are your line stats, Dev? ATM, your profile is correct for your sync and your throughput is correct for your profile. Put another way, BT are likely to say there is no fault. :(
DeViTTo
Its not line stats ahd some more network faults abut 2 weeks ago BT sorted that out yet again through IDnet support. Iwas on 4000K profile on friday with 3600 Downstream now I have suddenly been reduced to this. i cant check line stats as you know I have cable equipment.
There's not much we can say then, Dev. IDNet will be able to see the stats from their end.
DeViTTo
Dopamine
I'm on GW5 and my speeds have been up and down all day, from 5mbps to 700kbps.
    Actual IP throughput achieved during the test was - 1212 kbps
Since we've people now guessing that it's BT's fault, I'll add my guess: IDNet and various other ISPs now offer packages that have priority over their cheaper packages, ie Home SuperMax "With priority given at the exchange over standard ADSL traffic, Home SuperMax offers even faster speeds especially at peak times."
If contention or capacity usage is never a problem, I struggle to see why an ISP would need to offer a priority service. With all these reports of varying speeds that seemingly come and go at no specific times and at no specific locations, I wonder if it's not a case of our speeds being affected when the "priority" users start using their connections.
My complaint was passed to IDNet several days ago, and as yet I've had no report from them other than "The issue is very much in hand and we are working as quickly as possible to get to the root of the issue."
It's not ISPs that are offering better packages. These products are the office products that BT resell to ISPs. Whilst it's true that they do have priority at the exchange, I personally feel that being on a home product is not the cause of these issues. There is something not right at the moment. None of us know what that is, though we suspect BT, possibly 21CN maintenance.
i'll add that a isp will sell a supermax connection to help the user a cut through the congestion on bt's part of the network, not on their own.
zebrum
This is not broadband  :rant2:, how should we proceed?
#108
If you have problems, and we've ruled out all problems on your side, the best thing to do is contact support. :thumb:
Quote from: Sebby on Apr 07, 2008, 22:18:27
Ditto.  :)
DeViTTo
Well contacted Support, first they said that line checked out ok, but they had a word with BT once more now back on 5000Kb download as opposed to the 1mb I was on at the weekend. I'm glad they sorted it all credit to them Happy Customer again  ;D
Glad it's sorted, Dev.   :thumb:
If only BT didn't mess about in the first place...  >:(
zebrum
Quote from: Simon on Apr 07, 2008, 22:34:26
Ditto.  :)
Yeh done that first and they can't contact the people at BT they need to. Hmm I guess since there are no problems on IDNets network switching provider won't make a difference.
zebrum
Actually weirdly speeds have improved again just now
215.57K/s
Quote from: zebrum on Apr 16, 2008, 15:20:48
To be honest, IDNet have very good links with BT, and if there is a problem, you've got a better chance of getting it fixed with them, than with many other providers.
