BT engineers to strike?
Started by Rik, May 15, 2008, 12:34:41
El Reg is reporting that BT engineers will be taking industrial action over pay before May 27, initially in the form of a work to rule.
Hopefully, the impact will not be too great...
At least they won't be breaking things for a day!  ;D
My BT engineer is on route from the other side of town. Should just get here before the end of the am slot (which is 1pm)!
4 minutes and counting. Good luck.
Malc
Hopr they give advance warning of the date, so I can get all my downloading done on that day. :thumb:
Quote from: Lance on May 15, 2008, 12:58:05
He has just pulled up!
Timing! :) It might be worth unplugging the router while he works, to avoid and profile drops.
We will hopefully have no problems then! ;)
Den
Quote from: Rik on May 15, 2008, 12:34:41
Does that mean they will be working faster or slower or not at all or even, they will be working a bit. >:D
Mr Music Man.
We're hoping it means they stop breaking things, Den. :)
talos2
Work to rule?
                           Will we notice the difference then ?
                                               Even an improvement maybe ?
:hide2:
EX Orange and proud of it.
