How to ...
Started by Simon_idnet, Sep 20, 2006, 21:43:12
Nerval
Much obliged Rik - saved me searching  :laugh:
Looks like I've got interleaving enabled.
I think I read somewhere that BT now enable it by default on all new connections, so that will be no surprise given I'm new here..
[DSL Modem Stats]
        US Connection Rate:     448     DS Connection Rate:     5056
        DS Line Attenuation:    50      DS Margin:              2147483646
        US Line Attenuation:    28      US Margin:              24
        US Payload :            1364042016      DS Payload:             11079833
76
        US Superframe Cnt :     4484006 DS Superframe Cnt:      4484006
        US Transmit Power :     0       DS Transmit Power:      0
        LOS errors:             0       SEF errors:             0
        Frame mode:             3       Max Frame mode:         0
        Trained Path:           1       US Peak Cell Rate:      1056
        Trained Mode:           3       Selected Mode:          1
        ATUC Vendor Code:       54535443        ATUC Revision:  2
        Hybrid Selected:        1       Trellis:                1
        Showtime Count:         7       DS Max Attainable Bit Rate:     5088
        BitSwap:                1       US Max Attainable Bit Rate:     n/a
        [Upstream (TX) Interleave path]
        CRC:    432     FEC:    9180    NCD:    0
        LCD:    0       HEC:    0
        [Downstream (RX) Interleave path]
        CRC:    2265    FEC:    462455414       NCD:    0
        LCD:    0       HEC:    0
        [Upstream (TX) Fast path]
        CRC:    0       FEC:    0       NCD:    1
        LCD:    0       HEC:    0
        [Downstream (RX) Fast path]
        CRC:    0       FEC:    0       NCD:    0
        LCD:    0       HEC:    0
[ATM Stats]
        [Upstream/TX]
        Good Cell Cnt:  28417542
        Idle Cell Cnt:  52125358
        [Downstream/RX)]
        Good Cell Cnt:  23082987
        Idle Cell Cnt:  885835062
        Bad Hec Cell Cnt:       49182
        Overflow Dropped Cell Cnt:      0
You should re-boot your router now to shut off the telnet port, which is otherwise a bit of a security risk. Afraid I've never heard of a way to do it from the command line, which seems a bit silly, but...
Nerval
cheers
didn't know that - I must have left it open for days in the past.
will do.
It's plastered all over the net as a security issue, yet Netgear have never addressed it. Crazy...
Looking at your sig, I've had people ask me for GMail invites, whcih I've duly sent, yet they've never been take up. Makes you wonder...
Nerval
#29
They'll probably do it at the same time as they issue firmware to enable the router for Multicasting  :banana2:
Round about the twelfth of never I suspect.
Don't know if they're going down the pan, but they improved our user experience by shutting the forums not so long ago.
I've had quite  a few tGmail invites aken up, but I've still got about 3,000 left.  Don't know how much they use them.
Just discovered Tesco block Gmails. Daft.
Oh well, off to make the tea.
Quote from: Nerval on Nov 08, 2006, 16:53:12
Cliff Richard fan then? ;)
QuoteDon't know if they're going down the pan, but they improved our user experience by shutting the forums not so long ago.
They were never much use, were they.
QuoteI've had quite  a few tGmail invites aken up, but I've still got about 3,000 left.  Don't know how much they use them.
And Google blocks responses from ADSLGuide. Luckily, it's only there as a throwaway.
QuoteOh well, off to make the tea.
Sue's making mine as I type. ;)
Nerval
Cliff Richard fan then? Wink
Oddly enough, we're off to see him in Sheffield later this month.
:banana2: :banana2: :banana2: :banana2: :banana2:
You see what clues you can leave scattered behind you...   :out:
