High pings
Started by psp83, May 09, 2008, 18:22:56
Well its not been a good week connection wise, atleast my ping stayed good but tonight is a different story..
Tracing route to www.bbc.net.uk [212.58.251.207]
over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  192.168.0.1
  2   237 ms     *      203 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3   204 ms   203 ms   210 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4     *       87 ms    86 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    61 ms    62 ms    64 ms  212.58.238.129
  6    93 ms    92 ms    15 ms  212.58.239.58
  7    68 ms    70 ms    74 ms  www5.telhc.bbc.co.uk [212.58.251.207]
Trace complete.
  2    80 ms    78 ms   110 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3    15 ms    15 ms    15 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    66 ms    72 ms    70 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    25 ms    27 ms    39 ms  212.58.238.129
  6    79 ms    81 ms    80 ms  212.58.239.58
  7   101 ms   110 ms   105 ms  www5.telhc.bbc.co.uk [212.58.251.207]
Trace complete.
Fine here, Paul, with thunder around...
tracert www.bbc.co.uk
  1    <1 ms     1 ms    <1 ms  home [192.168.1.254]
  2    42 ms    23 ms    23 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3    28 ms    23 ms    23 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    24 ms    23 ms    23 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    24 ms    23 ms    23 ms  212.58.238.129
  6    25 ms    23 ms    21 ms  212.58.239.58
  7    23 ms    25 ms    23 ms  www5.telhc.bbc.co.uk [212.58.251.207]
Trace complete.
Tracing route to www.bbc.net.uk [212.58.253.72]
  2    26 ms    23 ms   120 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3    23 ms    23 ms    23 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    24 ms    25 ms    25 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  6    24 ms    25 ms    25 ms  te12-1.hsw0.cwwtf.bbc.co.uk [212.58.239.222]
  7    24 ms    23 ms    25 ms  www3.cwwtf.bbc.co.uk [212.58.253.72]
Trace complete.
tracert www.idnet.net
  2    25 ms    23 ms    23 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3    23 ms    25 ms    25 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    24 ms    25 ms    23 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  5    25 ms    23 ms    23 ms  redbus-gw1-fa0-0-301.idnet.net [212.69.63.209]
  6    23 ms    23 ms    23 ms  www.idnet.net [212.69.36.10]
Trace complete.
Must be the problems i am getting causing this aswell then  :(
Look like. Are you GW5 or DSL4? If the former, try dropping the PPP (not the DSLAM connection) and then start a new PPP session, see if that helps.
im dsl4
tried a reboot. got alittle better but not much
It's probably tied in to your line issues then. :(
No harm in letting IDNet know, even if it does relate to the line problems.
