New BT Speed Test
Started by Bill, Sep 13, 2006, 14:21:47
http://test.speedtester.bt.com:50301/
You'll need your IDNet login (whatever@uk.idnet.dsl4), and it will also tell you your BRAS profile.
Note- this one runs through IDNet, it's not the ISP-independant one. It also seems very busy or something at the moment (maybe it's still being tested), so you may need to keep trying...
equk
I entered phone no, then it went to "checking user details" then ....
QuoteUnexpected result received when querying the network to find your services connection details. Please try again shortly, but if this problem persists raise the issue with your service provider.
:( maybe it's down or something atm
e6400 @ 3.2Ghz 38°C 45°C | ATI X1900XT | P5W DH | ss: linux | osx
migration complete - sync 5mb 500k - stable low ping times
Thar
#2
I got that last night but got a different test error message this morning saying the tester was busy. It still didn't get beyond checking my details with my ISP though.
Anyone got it to work?
Just managed to complete the test. My details were accurate and the profile info is handy.
Danni
Been trying for a couple of hours now, getting various error messages. the most recent one is this:
Performance Tester is unavailable at the current time
Quote from: BT Performance Tester
Apologies, but the performance tester application is currently down for urgent maintenance. Please try again later.
I guess I'll have to do as it says :P
Thar
#4
Not surprised it's down. It's been coming up with some weird results like this -
Test1 comprises of Best Effort Test:
DSL connection rate: 500 kbps(UP-STREAM) 1000 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2802 kbps
Spot the mistake.
These are not my results by the way.  8)
equk
I just keep getting the test error :(
kuja
    IP profile for your line is - 6000 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  6816 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 4415 kbps
Thar
    DSL connection rate: 448kbps(UP-STREAM) 8128 kbps (DOWN-STREAM)
    Actual IP thoroughput achieved during the test was - 5676 kbps
These are my results :)
jimc
mm
mine says
The Performance Tester is now testing Broadband connection. Your configured download throughput speed for this service is 4000 k
then connection error
Test complete notification not processed successfully.
dont like that onfigured download throughput speed for this service is 4000 k
bit ?
Jeff
Aye, never got over the first fence ... will try again tho.
Thanx for informing us about this Bill :)
Thar
Quote from: jimc on Sep 15, 2006, 16:22:59
mm
mine says
bit ?
What do you think your download thoroughput speed should be?
I'd suggest you try it again if you think it's wrong as it's been coming up with some weird results, although mine were spot on.
karvala
I did a couple of times last night, and it worked for me:-
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 6683 kbps
Which also agrees with http://www.speedtest.bbmax.co.uk/re...364320&v=438042. :)
BassoProfundo
Worked well for me too  :)
    Actual IP throughput achieved during the test was - 6365 kbps
... and also agrees with BBMax speedtest:
Last Result:
Download Speed: 6358 kbps (794.8 KB/sec transfer rate)
Upload Speed: 373 kbps (46.6 KB/sec transfer rate)
Nice one guys, thanks.
jimc
still not working for me ???
Danni
Press the back button and resubmit- it took a few tries for me to get it working properly.
Now I can't remember my results, and I'm using the connection too much to get realistic results.
HungLO
I've been trying for thelast few days with no love. This is what I get:
It does not matter how many times I try, I always get the same error.
jimc
yeh
same here has never worked for me
maxping
Performance Tester was not able to find all the network details required for telephone number   ::)
mrapoc
I used to get that till i changed the firmware of my router and turned dmz mode on
jimc
tried it with 2 different routers so doubt its that ???
As much as anything, it seems to be time. I've only ever got past the 'checking' phase between 1 and 7am.
Nerval
Usually works for me, though occasionally gives spurious errors like saying I've got the phone number wrong, and occasionally says it's too busy.
Linc
Bet its a good Test.................if it worked!!!
