Problem with Avatar
Started by Nerval, Nov 20, 2006, 15:59:08
Nerval
Animated GIFs  uploaded to the forum as avatars do not seem to stay animated.
Is this a design feature, or did I do something wrong?
I tried that as imageshack went down and Rikbean recommended upping to the forum as an alternative.  Meanwhile, I've moved it to photobucket.
Bat
Hi,
Mines the same, I uploaded form my PC onto here.  ???
You want to see him play those drums! :D
Cheers,
Gavin :)
Nerval
Well imageshack is back up now, so you can use that  though mine's still on Photobucket.com.
Can't wait for the action from yours  :laugh:
Bat
Hi,
It works if hosted elsewhere! :)
Cheers,
Gavin :)
Nerval
Brilliant!
Well worth the effort.
I'd say it's just a  :banana2: bit more animated than my cat
