Getting disconnects...
Started by dlorde, Oct 10, 2008, 19:11:12
dlorde
Am I the only one getting the disconnections this time?
I've had several recently (no change in my configuration or hardware) - latest modem log as follows:
10/10/2008  19:05:38 If(ATM1) PPP connection ok !
10/10/2008  19:05:36 ATM1 start PPP
10/10/2008  19:05:36 Dial On Demand(ATM1)
10/10/2008  19:02:51 NTP Date/Time updated.
10/10/2008  18:53:40 ATM1 get IP:91.135.**.***
10/10/2008  18:53:27 If(ATM1) PPP fail : Unknown error or UI Connect/Disconnect
10/10/2008  18:53:25 ATM1 start PPP
10/10/2008  18:53:25 Dial On Demand(ATM1)
10/10/2008  18:53:23 192.168.2.3 login success
10/10/2008  03:22:38 NTP Date/Time updated.
10/10/2008  03:18:41 Can't find NTP time.
10/10/2008  00:24:59 If(ATM1) PPP connection ok !
10/10/2008  00:24:58 ATM1 get IP:91.135.**.***
10/10/2008  00:24:48 ATM1 start PPP
10/10/2008  00:24:48 Dial On Demand(ATM1)
10/10/2008  00:24:42 192.168.2.3 login success
10/10/2008  00:09:48 ATM1 stop PPP
10/10/2008  00:09:38 ATM1 get IP:91.135.**.***
Edit: personal data removed.
Nothing here, as far as I am aware.
Ted
Might be a good idea to remove your IP address from your post, just in case  :)
Ted
Damn, I should have noticed that.  Thanks Ted, done now.
It's probably just a "glitch" somewhere along the line (no pun intended). :)
all ok here on dsl4  in sunny cornwall.
dlorde
Quote from: Simon on Oct 10, 2008, 22:50:58
Ouch! Thanks guys - wasn't thinking...
