Problem with PPP after MK failure
Started by lozcart, Aug 19, 2009, 19:42:11
I've spoken to Brian who tested my line and it's not showing any faults. He suggested trying a different modem which I did but it was exactly the same holding sync but dropping PPP every few minutes with no data throughput when connected. Brian said he would ask BT to check on the fault tomorrow.
Tried my connection this morning and now back on line  :thumb:
My PPP kept dropping every 3-4 minutes up until 6.13am this morning, after that time everything has kept connection.
I guess BT were doing some secret work no one knew about :mad:
:fingers: everything is OK this evening.
It does sound that way, Loz, perhaps a residuary from the MK node failure.  :fingers:
