Modify/edit posts?
Started by Noreen, Jul 27, 2007, 18:57:30
Noreen
I've seen in the Help section that there is a modify button but I couldn't find it in my post, is there one?
Hi Noreen, there is a button in the top right of posts you have made...BUT...it disappears after a preset time,you do not have long to go back and alter mistakes.
Noreen
#2
Thanks, I wonder what that time is because it would be handy to know. For instance there is no modify button now on my previous post in this thread.
edit: just checked with this post and as you say there is one at the moment.  :)
The time limit is 30 minutes, Noreen. After that time, you can ask a staff member to make a modification for you.
Noreen
