Help-signed up but still not connected!
Started by Kitty, Dec 30, 2006, 00:29:19
stevelondon
I can help you with that its no problem.
Mr Booh
Hi Kitty,  How goes it with your connection probs?
Kitty
Thanks for asking-I haven't had the energy to deal with it. Car broke down this morning so too stressed out for more stress if you see what I mean!
I will probably wait to call idnet tomorrow unless I get a burst of enthusiasm.
Just one thing though, I can't get into my hotmail account-I click on it in my favourites as usual but it "times out".........any ideas?
thetrevone
#28
Kitty,
I have recommended two people to IdNET who have bought the speedtouch routers from them (not sure off-hand if they were wireless ones or not now) but in both cases although some months apart there was rather a crucial mistake (and for all I know may still  be in that bit of paper that comes with it). does it  say 'admin' as the username if it does it could well be 'Administrator' (as stevelondon has stated) I phoned about this as I had entered 'admin' as requested and was getting a username /password invalid. Apparantly it was well known, but nobody thought it worth correcting on the paper it seems, without it, it will be impossible to talk to the router through the web interface. They may have fixed this now and it may not be applicable to your speedtouch, but just in case I would check with CS in the morning.
Regards
Doug
stevelondon
yes its Administrator with a capital A and without a password unless idnet change the login to admin in the configuration if so the username will be admin and the password will also be admin as once you change the login username the password is the same.
Kitty
Thanks so much everybody for your kindness-I only just noticed that I had messages in my inbox too!
The problem is not solved as
A; the instructions were not quite right but
B, in any case I couldn't connect as BT have messed up the connection!
Miriam is doing her best to chase them up and sort it out.
I can't wait to be reconnected-it has been like living in the dark ages for over a month!
I run a small animal charity and haven't been able to do what I need to do.
I am still wondering why I cannot access my hotmail account-probably a coincidence but grateful for any ideas. There might be some important emais that I am missing-makes me worry!
Kitty
thetrevone
Hi Kitty
Thanks for the update, sorry I can't help you with hotmail. Good luck
Regards
Doug
Hi Kitty,
Glad you are on your way to sorting your connection.
There is no logical reason why you shouldn't be able to access Hotmail via your Dial-Up Connection.
Mine works fine from anywhere, any connection.
Kitty
Hi
In all the messing about, perhaps I have changed something although I can't imagine what.
I have never had a problem before and have had an account for a few years. I  have been on dial -up for the last month while waiting for my broadband and it has been fine. It is just the last few days, coinciding with my trying to connect to my new broadband.
I cannot get in via google or any way-it just times out. Nothing else is timing out.
Heeeeeeeelp!
Just a thought Kitty what browser are you using, if you have IE7 there is a bug that causes problems signing in to M$ sites.
Kitty
Hi Dorset,
It just suddenly started working again-very odd! : ??? I use Firefox by the way.
Nothing would suprise me with M$/Messenger/Windows Live.............hope it keeps running for you now and the numptys er BT get your line sorted asap.
Kitty
Hurrah-almost 5 weeks after signing up to idnet, I am connected!
It is not idnet's fault as they have to rely on BT who kept pretending to fix the fault! After many failed attempts at the exchange a BT engineer failed to turn up at my house yesterday morning. Idnet contacted one of the big fellas there and by last night, it was at long last fixed at the exchange. It seems to be fluctuating a bit but hey, I'm back to broadband. Perhaps it's just settling in!
Idnet have been really helpful as have some of you out there. Thank you for the moral support even though it seems all the advice in the world wouldn't have helped in the end unless you were a BT engineer!!
Cheers everybody.  :D
Kitty
Eureka, at long last you are truly one of us now Kitty.
Thanks for the update, great news.
AT LAST!!!!!!!!
Good to know you are up and running now.The line will vary for the first 10 days or so (and then vary at peak times because of BT's dodgy network  :D )
Have another Karma for your patience and to celebrate  ;D
maxping
stevelondon
Blimey!!! Kitty lol welcome to IDNet at last  ;D :banana2: :out:
thetrevone
Great news kitty.
Amazing patience you have.
Regards
Doug
ou7shined
Welcome back to the 21st century ;D
and to the forum where we say it with....er....bananas :laugh:
Rich.
Klaatu barada nikto!
