sync speed
Started by Colin Burns, Mar 01, 2008, 01:13:34
Colin Burns
yay
im just happy with my sync speed and though put im getting
DSL Line (Wire Pair):     Line 1 (inner pair)
Protocol:    G.DMT Annex A
Downstream Rate:    6688 kbps
Upstream Rate:    832 kbps
Channel:    Interleaved
Current Noise Margin:    15.0 dB (Downstream) 14.0 dB (Upstream)
Current Attenuation:    24.4 dB (Downstream) 12.5 dB (Upstream)
Current Output Power:    19.8 dBm (Downstream) 12.4 dBm (Upstream)
DSLAM Vendor Information:    Country: {0xB5} Vendor: {TSTC} Specific: {0x00}
PVC Info:    0/38
with a jolly 5mb though put
and i dont even have my new filters ordered yet
Thanks everyone for the help
That's not a bad result, Colin. You now need to maintain that sync for 14 days and hope the margin starts to reduce, you can probably get another 1000k from the line yet.
Dangerjunkie
Hi Colin,
Quote from: Colin Burns on Mar 01, 2008, 02:24:46
i could resight my router next to the MS but it would result in having to wake my parents up every time i need to restart my modem at early hours in the morning will see if i have a ring wire and report back but sadly will have to be later today
You could put the modem in there and get something like one of these (Maplin N97CQ) so you could power-cycle the modem without having to go into the room: http://www.maplin.co.uk/search.aspx?MenuNo=12067&MenuName=Remote%20Control%20Sockets&worldid=-4&FromMenu=y&doy=12m3
Cheers,
Paul.
Excellent, Colin. As Rik mentioned, if you can leave it sync'd for 14 or 15 days, your noise margin should drop by 3dB. Eventually you should get the maximum sync. :)
