Something seriously wrong?
Started by PetFish, Aug 26, 2008, 18:27:46
BrianM
Speeds gradually getting slower here in Yorkshire the last few days too, not complaining, it's still ok for me.
  BT Speedtester 21/07/08
    Your DSL connection rate: 6816 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 5500 kbps
    Actual IP throughput achieved during the test was - 5114 kbps
BT Speedtester 28/08/08
    Your DSL connection rate: 6048 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 4500 kbps
    Actual IP throughput achieved during the test was - 4208 kbps
Brian
Take care of all your memories. For you cannot relive them.
You've had a lower speed sync event to get that 4500 profile, Brian. It suggests a local noise issue, is there any information in the router logs?
That throughput looks fine for a 5,500k profile, Brian. The profile is wrong, though, probably due to some instability lately.
john
I have also noticed things have been a bit slow lately, my BT Speedtester results for today (28/08/08) are as follows :
    Your DSL connection rate: 5920 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 5000 kbps
    Actual IP throughput achieved during the test was - 2527 kbps
Please get in touch with IDNet about this. There are a few people suffering, so it'll be good for them to gather some information.
john
Results sent to Idnet Sebby as advised.
David
Mines down again so have sent results over...hope it helps thanks Sebby :thumb:
David
