PC Dead ?
Started by David, Sep 30, 2008, 08:32:44
David
Well it on now and I have connected it up to the internet etc...onthe welcome screen ,no warnings nothing I would have expected something.but as Im still chasing them up I will leaave this and see..nothing to lose really
It sounds like just a loose connection somewhere David, but what do I know..  ;D
Glad it's working. :thumb:
I'm disappointed by the PC World response time, David. Maybe you should be mentioning the Sale of Goods Act to them?
David
Yes I am not that happy with them and will think twice i future....I know it was a web sale but this isnt the point.
Everything is ok.it will not turn off .....I managed it via the keyboard but its going back but I can get the data off the hard drive which is good nesw for me
Very good news.  :thumb:
David
Just returned from PC World and been givena different phone number,apparently it will be collected by courier and returned when fixed.
AS there is no seal and as a tap on the top seems to put everything right I will have the back off and check,it has to be a loose connection...so before I let them loose on it.....,.I will try.
Worst ways it goes back best ways  I will save myself a time without  my PC got to be worth a punt :fingers:
Looking can do no harm, David, and if you find something loose, a gentle push will soon establish if that was the problem.
It sounds almost certain that it is just a loose component David, I would do as Rik suggests. ;)
David
Be sure to earth yourself first David, I just put my hand on the computer case and the cold tap first just to discharge any static.
David
Thanks In I will do this, already got my anti static wrist band out....
Quote from: badpianoplayer on Oct 07, 2008, 15:45:54
Do they come " free of charge " David?... ;D :out: :duck:
David
Quote from: Inactive on Oct 07, 2008, 15:39:04
Mental images of an Orangutang mending a computer ;D
Thanks. otherwise known as "The old man of Borneo PC repairs"
Is that anything like the Old Man of Hoy?  ;D
Quote from: stevethegas on Oct 07, 2008, 16:49:39
Watch it.... ;D :buttkick:
David
You could say " Hoy Watch it" ;D
David
David
Well after all that and sending a broadside yesterday to PC world the Acer was collected first thing this morning...last night do you think I could get the thing to break down...no no matter what I did it carried on regardless..,so I have listed the faults on it and hope they can test it.The guy on the phone yesterday took all the details but I told him anyway...what I did discover when I shook it gently,there is a screw or something metalic rattling around inside the case,and on inspection the AV in and the airial socket are at an angle ?
Im now hoping it wont be too long before its is back and also they give it a good check over?I assume they can test cards and connections etc......is there a tester which would indentify a fault..or would the machine need to play up when they switch on ?
There are some tests that they can run, David, but I suspect it simply needs a good visual inspection and some firm prodding of connections.
