Help Please.. It's all over the place!
Started by Bat, Dec 25, 2006, 22:35:28
Bat
Hi,
I've attached my router stats at the bottom. Although my speed and SNR look good, CRC and errored seconds are rising fast. My speeds and surfing fluctuate dramatically. I can do one speed test at 3125 and the next at 2! Surfing is the same, sometimes get a server not found or DNS error. Had problem for 2 days now, switched router off for half an hour, still no better. Any ideas anyone?
Cheers,
Gavin :)
[attachment deleted by admin]
Bat
Hi,
The Modify button has disappeared! So another post to tell you that I checked last night and my exchange is actually green!
Cheers,
Gavin :)
ou7shined
Maybe xmas is a real busy time for the tinternet. I've noticed a bit of lag today. Try again later.
Oh BTW if you disable that network connection that shows up as disconnected in your task bar, it'll disappear for ya. ;)
Rich.
Klaatu barada nikto!
Quote from: Bat on Dec 25, 2006, 23:50:12
Hi,
Cheers,
Gavin :)
Modify works strangely. For a very short while, it will allow you to change a post without it being marked as edited. Then it will allow you to make a change, but will mark the post as edited. Then it disappears. I haven't worked out the timings, though. :(
