High Pings earlier .
Started by maxping, Jan 06, 2007, 18:56:56
maxping
I have been getting pings into the 80's in the last couple of Horus so tried the BT log in (as explained in the first post in the "how to fix high pings" thread)
I didn't use the speed test just logged in and then put my idnet user name back in and rebooted router.
Before using BT log in
Reply from 212.69.36.10: bytes=32 time=64ms TTL=60
Reply from 212.69.36.10: bytes=32 time=44ms TTL=60
Reply from 212.69.36.10: bytes=32 time=54ms TTL=60
Reply from 212.69.36.10: bytes=32 time=70ms TTL=60
    Minimum = 44ms, Maximum = 70ms, Average = 58ms
After using BT log in.
Reply from 212.69.36.10: bytes=32 time=32ms TTL=60
Reply from 212.69.36.10: bytes=32 time=30ms TTL=60
Reply from 212.69.36.10: bytes=32 time=27ms TTL=60
Reply from 212.69.36.10: bytes=32 time=34ms TTL=60
Reply from 212.69.36.10: bytes=32 time=43ms TTL=60
Reply from 212.69.36.10: bytes=32 time=45ms TTL=60
Reply from 212.69.36.10: bytes=32 time=57ms TTL=60
Reply from 212.69.36.10: bytes=32 time=33ms TTL=60
Reply from 212.69.36.10: bytes=32 time=39ms TTL=60
Reply from 212.69.36.10: bytes=32 time=29ms TTL=60
Reply from 212.69.36.10: bytes=32 time=31ms TTL=60
Reply from 212.69.36.10: bytes=32 time=52ms TTL=60
Reply from 212.69.36.10: bytes=32 time=55ms TTL=60
Reply from 212.69.36.10: bytes=32 time=35ms TTL=60
Reply from 212.69.36.10: bytes=32 time=38ms TTL=60
Reply from 212.69.36.10: bytes=32 time=40ms TTL=60
Reply from 212.69.36.10: bytes=32 time=36ms TTL=60
Reply from 212.69.36.10: bytes=32 time=26ms TTL=60
maxping
#1
Seems fine again now not even getting the spikes into the 50's
For those not used to pinging from start/progs/accessories/command prompt.
Type ping -t idnet.net (or whatever address you want to ping)
Adding the -t will let the test run for as long as you want it to , stop it by right clicking once , click "mark" , left click and drag the white box over the part you want to save and hit "enter" to save it so you can paste it into your post.
Reply from 212.69.36.10: bytes=32 time=25ms TTL=60
Reply from 212.69.36.10: bytes=32 time=28ms TTL=60
Reply from 212.69.36.10: bytes=32 time=24ms TTL=60
Reply from 212.69.36.10: bytes=32 time=41ms TTL=60
Reply from 212.69.36.10: bytes=32 time=42ms TTL=60
mrapoc
all normal here - i wasnt on my pc at the time you got high pings, too busy watching the gunner pwn liverpool 3-1  :D
Can't even get BT Speedtester to work!
Enter phone number................................................35 mins later still waiting for the next stage.
Forum took over a minute to open and signing in another 45 secs+.
maxping
#4
I spoke too soon  :'(
Can a few of you peeps ping 87.117.208.22  for me and post the results , Ta.
I would try switching the router off for 30 mins but i wont be on again after 9:00 so  will try again in the morning.
Tracing route to 87.117.208.22 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  192.168.1.254
  2     *       31 ms    25 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    24 ms    32 ms    33 ms  212.69.63.10
  4     *        *       27 ms  x-s-1.lon1.arbinet.net [213.232.64.54]
  5    38 ms    32 ms     *     lon-sb1.LON.GB.net.DTAG.DE [62.154.15.153]
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *       30 ms     *     87.117.208.22
10    28 ms     *       27 ms  87.117.208.22
Trace complete.
Tracing route to idnet.net [212.69.36.10]
over a maximum of 30 hops:
  2     *       24 ms    25 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    39 ms    44 ms    51 ms  212.69.63.10
  4    71 ms    62 ms    61 ms  redbus-gw.idnet.net [212.69.63.1]
  5    84 ms    96 ms    73 ms  www.idnet.net [212.69.36.10]
Trace complete.
  2  2223 ms  1196 ms   177 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    27 ms    26 ms    30 ms  212.69.63.10
  4    58 ms    41 ms    48 ms  redbus-gw.idnet.net [212.69.63.1]
  5    70 ms    58 ms    50 ms  www.idnet.net [212.69.36.10]
AvengerUK
my pings went high earily aswell not so bad now, However i am seeing alot of loss to some locations which i didnt previously get, also pings are still slightly suffering - but not as bad as before!
BTW: your IP as well with pinging multiplay times out alot (loss)
ou7shined
Here you go Max. Sorry I couldn't be bothered copying it out.
Rich.
Klaatu barada nikto!
maxping
Thanks - its as bad again this morning , i will wait and see if Simon sees the thread and can shed any light on it.
Tracing route to bbc.co.uk [212.58.228.155]
  2   164 ms   308 ms   323 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    22 ms    31 ms    23 ms  212.69.63.10
  4    23 ms    26 ms    23 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    22 ms    24 ms    23 ms  212.58.238.153
  6    23 ms    24 ms    23 ms  212.58.238.36
  7    24 ms    25 ms    25 ms  pos6-0.rt1.mh.bbc.co.uk [212.58.239.254]
  8    24 ms    26 ms    26 ms  virtual0.mh.bbc.co.uk [212.58.228.155]
Trace complete.
  2    22 ms    22 ms    23 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    24 ms    24 ms    23 ms  212.69.63.10
  4    24 ms    24 ms    23 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    22 ms    25 ms    24 ms  212.58.238.153
  6    24 ms    23 ms    24 ms  212.58.238.36
  7    25 ms    25 ms    26 ms  pos6-0.rt1.mh.bbc.co.uk [212.58.239.254]
  8    25 ms    26 ms    24 ms  virtual0.mh.bbc.co.uk [212.58.228.155]
Trace complete.
  2    23 ms    22 ms    22 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    23 ms    23 ms    23 ms  212.69.63.10
  4    22 ms    24 ms     *     x-s-1.lon1.arbinet.net [213.232.64.54]
  5     *       23 ms    24 ms  lon-sb1.LON.GB.net.DTAG.DE [62.154.15.153]
  6    24 ms    24 ms    24 ms  217.239.39.230
  7    24 ms    25 ms    24 ms  217.6.48.238
  8    23 ms    25 ms     *     ge-1-24.pup.mer.lon.rapidswitch [87.117.214.2]
  9    24 ms    25 ms     *     87.117.208.22
10    27 ms    24 ms    25 ms  87.117.208.22
Trace complete.
  2     *      192 ms    23 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    23 ms    23 ms    22 ms  212.69.63.10
  4    23 ms    23 ms    23 ms  x-s-1.lon1.arbinet.net [213.232.64.54]
  5    23 ms    24 ms    23 ms  lon-sb1.LON.GB.net.DTAG.DE [62.154.15.153]
  6    23 ms    23 ms    75 ms  217.239.39.230
  7    25 ms    24 ms    25 ms  217.6.48.238
  8    25 ms    24 ms    23 ms  ge-1-24.pup.mer.lon.rapidswitch [87.117.214.2]
  9    26 ms    28 ms    25 ms  87.117.208.22
Trace complete.
  3    24 ms    23 ms    22 ms  212.69.63.10
  4    23 ms    25 ms    24 ms  x-s-1.lon1.arbinet.net [213.232.64.54]
  5    24 ms    23 ms    30 ms  lon-sb1.LON.GB.net.DTAG.DE [62.154.15.153]
  6    23 ms    25 ms    23 ms  217.239.39.230
  7    25 ms    23 ms    25 ms  217.6.48.238
  8    29 ms    32 ms    24 ms  ge-1-24.pup.mer.lon.rapidswitch [87.117.214.2]
  9    25 ms    24 ms    28 ms  87.117.208.22
Trace complete.
  2    22 ms    23 ms    24 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    24 ms    25 ms    23 ms  212.69.63.10
  4     *        *        *     Request timed out.
  5    24 ms    26 ms    24 ms  lon-sb1.LON.GB.net.DTAG.DE [62.154.15.153]
  6    24 ms    23 ms    23 ms  217.239.39.230
  7    28 ms    27 ms    26 ms  217.6.48.238
  9    24 ms     *        *     87.117.208.22
10    26 ms    24 ms    25 ms  87.117.208.22
Trace complete.
maxping
This is strange , i get no problems using the bbc   ???
  2    22 ms    22 ms    28 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  5    23 ms    23 ms    23 ms  212.58.238.153
  6    24 ms    23 ms    23 ms  212.58.238.36
  8    25 ms    25 ms    25 ms  virtual0.mh.bbc.co.uk [212.58.228.155]
Trace complete.
  1    <1 ms    <1 ms     2 ms  192.168.1.254
  2    23 ms    22 ms    24 ms  telehouse-gw-msdp.idnet.net [212.69.63.41]
  3    25 ms    23 ms    23 ms  212.69.63.10
  4    23 ms    24 ms    24 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    23 ms    24 ms    25 ms  212.58.238.153
  6    23 ms    23 ms    23 ms  212.58.238.36
  8    24 ms    24 ms    25 ms  virtual0.mh.bbc.co.uk [212.58.228.155]
Trace complete.
  3    24 ms    23 ms    24 ms  212.69.63.10
  4    25 ms    23 ms    26 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    23 ms    23 ms    24 ms  212.58.238.153
  7    25 ms    24 ms    28 ms  pos6-0.rt1.mh.bbc.co.uk [212.58.239.254]
Trace complete.
When you're having high ping problems, why do you quote traceroutes? The intermediate figures mean nothing unless the the values go high at one point and remain high beyond it. The sporadic high value on the telehouse router just means it's fairly busy, it doesn't affect the time to the destination server.
I tried pinging IDNET last night........pings at 385ms :( ,  waited 2 minutes and pinged again.........only 42ms ???
My broadband connection has also been dropped though the router stats clearly showed that the power had NOT been off.
The speeds were so bad this morning I have rebooted the router and will have to see where this takes us.
Quote from: Bill on Jan 07, 2007, 12:00:44
Just means that many people are probably pinging and tracerting.  ;)
maxping
#12
Bill if i had of known that i wouldn't have  ;)
I did ping in the op before i tried the BT log in  and it shows high pings.
I have Pinged both servers this morning that were showing high last night and all seems well again, i will keep my fingers crossed.
Pinging 217.146.92.144 with 32 bytes of data:
Reply from 217.146.92.144: bytes=32 time=34ms TTL=120
Reply from 217.146.92.144: bytes=32 time=25ms TTL=120
Reply from 217.146.92.144: bytes=32 time=28ms TTL=120
Reply from 217.146.92.144: bytes=32 time=23ms TTL=120
Ping statistics for 217.146.92.144:
    Minimum = 23ms, Maximum = 34ms, Average = 27ms
Reply from 217.146.92.144: bytes=32 time=24ms TTL=120
Reply from 217.146.92.144: bytes=32 time=26ms TTL=120
    Minimum = 23ms, Maximum = 26ms, Average = 24ms
    Minimum = 23ms, Maximum = 24ms, Average = 23ms
Pinging 87.117.208.22 with 32 bytes of data:
Reply from 87.117.208.22: bytes=32 time=26ms TTL=121
Reply from 87.117.208.22: bytes=32 time=24ms TTL=121
Reply from 87.117.208.22: bytes=32 time=25ms TTL=121
Ping statistics for 87.117.208.22:
    Minimum = 24ms, Maximum = 26ms, Average = 25ms
    Minimum = 24ms, Maximum = 26ms, Average = 24ms
Reply from 87.117.208.22: bytes=32 time=27ms TTL=121
    Minimum = 24ms, Maximum = 27ms, Average = 25ms
maxping
Just read this at the TB idnet forum in the "Latency Issues thread.
A co-lo customer had a problem with one of their sites being used to relay a flood of spam. They managed to fix that problem with help from our team. Apologies to anyone affected.
Quote from: maxping on Jan 07, 2007, 12:43:33
YES MAX............on the 28/12/2006 ;D ;D
maxping
Quote from: DorsetBoy on Jan 07, 2007, 14:42:36
Ooooops  :-[  well spotted.
Seems to be sorted whatever it was.  ;)
Not sorted here.............too eratic to be worth having the PC running!
Nerval
Browsing erratic here too Dorset, and I'm  far away from Dorset.  :laugh:
AvengerUK
Also very erratic my end -  pings are "ok" to some places and awfull to others.
AvengerUK
Quote from: maxping on Jan 07, 2007, 14:59:58
Just noticed: there is a reply from simon today in that thread - at around 1:30 "no network problems" apparently!
It's possible that school holidays, it's a weekend and this announcement may not be unconnected with the problem...
AvengerUK
actually school holidays ended *i believe* for most schools last week sometime?!
Anyway - pings are still the same ;) - its not bad so doesent stop me doing what i need to do though :)
maxping
Quote from: AvengerUK on Jan 07, 2007, 17:19:26
My Sons first day back is tomorrow.
ou7shined
Quote from: AvengerUK on Jan 07, 2007, 16:50:25
Apparently indeed. :-\
Rich.
MikeT
I am getting very slow site page loading times with Pipex dsl too so it may be a big problem somewhere on the network. Even tried using their webcache and that sped things up a little for a while but now its just as bad. ADSLguide speed test for my 1meg connect just gave this result.
Date     07/01/07 22:35:45
Speed Down    389.38 Kbps ( 0.4 Mbps )
Speed Up    241.45 Kbps ( 0.2 Mbps )
So seems its something general to all, unless of course I am missing something.
