Any problems today?
Started by psp83, Nov 22, 2008, 15:17:00
I'm sync'd at 4.5mb and only getting < 2mb speeds plus i'm getting loads off "Connection Interrupted" when visiting websites.
No problems with me, Paul and I've seen no other reports here or on TB. What are your router stats like?
ADSL Link     Downstream     Upstream
Connection Speed    5056 kbps    448 kbps
Line Attenuation    39 db    12.5 db
Noise Margin    12 db    27 db
No disconnections or drop in sync in 404 hours
Can you try a BT test to establish your profile?
this morning it was 4500 profile. I cant load bt speedtester now as i keep getting
Quote
The document contains no data.
The network link was interrupted while negotiating a connection. Please try again.
like many other sites aswell
What happens if you try a continuous ping to a site?
gives "request timed out"
The ip is to speedtester.bt.com
I wonder if that is set not to respond. Try www.idnet.net. My result is:
ping www.idnet.net
Reply from 212.69.36.10: bytes=32 time=25ms TTL=59
Reply from 212.69.36.10: bytes=32 time=26ms TTL=59
Reply from 212.69.36.10: bytes=32 time=23ms TTL=59
    Minimum = 23ms, Maximum = 26ms, Average = 24ms
Slightly slower than normal, but nothing significant.
IDnet website are fine.
C:\Users\Paul>ping www.idnet.net
Reply from 212.69.36.10: bytes=32 time=13ms TTL=59
    Minimum = 13ms, Maximum = 13ms, Average = 13ms
Connection Interrupted has seem to stop on most sites now but speeds are still slow.
I've given the router a reboot to see if that helps.
If it doesn't, give the out of hours number a ring, Paul: 01462 247 6556.
J!ll
About time I put mine up
Connection Speed    4800 kbps    448 kbps
Line Attenuation    46 db    15 db
Noise Margin    6 db    20 db
Nowt wrong there, on paper anyway, Jill. How's your son doing, btw, you haven't mentioned him for a while.
J!ll
J!ll
He came home with a friend (male) while we were away and last weekend. I think he can come each week now, but not sure  :D He has passed his LMG test and got marksman  :thumb: cannot post anymore pictures, not that he will let me have them! as he is not allowed, plus I'm told they are all being watched?  :dunno:
Don't worry, Jill - we're all being watched. ;)
J!ll
J!ll
Quote from: J!ll on Nov 22, 2008, 16:32:26
Looking good, Jill. The stats are alright as well. :P
J!ll
