High pings (again)?
Started by RostokMcSpoons, Jan 16, 2007, 19:47:14
RostokMcSpoons
[Posted on the TB forums too]
Damn, just when I thought they'd been fixed...
Reply from 212.69.36.10: bytes=32 time=120ms TTL=61
Reply from 212.69.36.10: bytes=32 time=123ms TTL=61
Reply from 212.69.36.10: bytes=32 time=141ms TTL=61
Reply from 212.69.36.10: bytes=32 time=117ms TTL=61
Minimum = 117ms, Maximum = 141ms, Average = 125ms
Pinging bbc.com [212.58.224.126] with 32 bytes of data:
Reply from 212.58.224.126: bytes=32 time=117ms TTL=250
Reply from 212.58.224.126: bytes=32 time=139ms TTL=250
Reply from 212.58.224.126: bytes=32 time=150ms TTL=250
Reply from 212.58.224.126: bytes=32 time=157ms TTL=250
Ping statistics for 212.58.224.126:
Minimum = 117ms, Maximum = 157ms, Average = 140ms
Tracing route to idnet.com [212.69.36.10]
over a maximum of 30 hops:
1 35 ms 27 ms 29 ms telehouse-gw-msdp.idnet.net [212.69.63.41]
2 141 ms 142 ms 117 ms 212.69.63.10
3 124 ms 105 ms 99 ms redbus-gw.idnet.net [212.69.63.1]
4 79 ms 83 ms 83 ms www.idnet.net [212.69.36.10]
Trace complete.
edit:  never mind - seems to have settled down again.   Very odd though.
maxping
Mate they ain't going to be "fixed" until Feb when we get more capacity.
You can however try to get lower pings by using the BT log in trick, its never failed me yet though sometimes it  needs a couple of goes.  ;)
RostokMcSpoons
Pings have gone back up.
I'm supposed to be playing in a clan match in half an hour, this is putting paid to that.
<sob>
Have we got any better estimate than just 'February'?  I can wait til February 1st.. but not until February 28th...
maxping
Did you try the BT log in trick?
http://www.idnetters.co.uk/forums/index.php/topic,1154.0.html
As for the estimated time i guess Simon is the best person to answer , remember its good old BT so i guess theres no guarantees
mrapoc
turn router off for half an hour as a last resort?
