ubuntu help needed
Started by psp83, Dec 12, 2008, 18:29:42
Hi all.
Anyone here that can help me with ubuntu?
I've built servers before but only with 1 HDD in them. The server i just built for work has 3 HDD in it.
1st HDD 250gb, main OS etc.
2nd HDD 500gb, main dev storage
3rd HDD 500gb, file storage (not connected yet as sata cable came broke and waiting for replacement)
My trouble is, how the hell do you mount the 2nd hard drive to the folder /media/www that has been created with "sudo mkdir /media/www"  ???
I've done "sudo fdisk -l" and heres a pic of the screen (the part in the red box on the bigger pic)
*click for bigger one
Also i want this drive to be mouted automatically on reboots.
Grateful for any help
Paul
Ok,
the following is a perfect example why I like a GUI rather than a command line
Brian, who is my Ubuntu Server bod says ...............
to partition the drive enter "sudo fdisk /dev/sdb"
when fdisk starts "m" gives you the command list
"n" is the command for a new partition
It will ask for a partition number (which should be 1) make it primary, then it will ask for size
This can be in bytes, kilobyte (end number with K) or megabytes (end number with M)
Check the system id ("t" in the command list)  82 is the number for the linux ext3 format
Back at the main menu press "w" to write to disk
to mount the partition at boot time we must edit the fstab so "sudo nano /etc/fstab"
once inside we add this line (no quotes)
"/dev/sdb1       /media/www      ext3   relatime   0   2"
to mount it after boot we type
"sudo mount /dev/sdb1"
Is there any issue with using the GUI with Ubuntu server? or am I just being a philistine. I suppose its senility I just cannot be bothered to learn all those commands and switches.
Quote from: stevethegas on Dec 12, 2008, 20:10:32
People say the gui uses more process power but to be honest i dont know if thats true. I use command line as i use SSH alot etc.
Plus i want to fully learn linux and the only way for servers is command line.
Quote from: kinmel on Dec 12, 2008, 20:03:02
Ok,
Thank you. I will give this ago when i get into the office monday. It doesn't seem that hard to add another HDD after all  ;D
First time for everything though  :)
Quote from: psp83 on Dec 12, 2008, 20:21:11
Enjoy it from my brief exposure to Ubuntu, it was nice to realise that I had some control over what was going on for once. ;D
The GUI certainly adds more processes that the server does not require to function. The hardware overhead is minimal and most machines can more than cope with the extra work, so why not add the GUI ?
I don't doubt that if you take the trouble to learn it all, it gives you greater control, but it isn't necessary to keep normal Ubuntu installations working properly.
I have now mounted the 500 GB HDD (/dev/sdb1) to /home/www insted of /media/www (following your post kinmel, just replacing media with home after doing sudo mkdir /home/www)
Problem is, when running a php script to give free space. it gives me 211.64 GB free. Does this mean its picking up the space from the main drive and not the mounted 500 GB HDD ?
Brian tells me ....
Hard to say without seeing the script.
There is a program for disk space called "Disk usage Analyzer" in the accessories menu this will show total filesystem space and usage
Quote from: kinmel on Dec 15, 2008, 11:33:33
Brian tells me ....
Was my mistake. forgot to put the path into the function.
I did disk_free_space("/"); insted of disk_free_space("/home/www");
putting df -h into the command line tells me /home/www has 435 GB left.
I think we need to get brian signed up here!
Quote from: Lance on Dec 15, 2008, 23:13:18
He spends all his time in Ubuntu forums  ;D
We could always give you a dedicated Linux board. ;D
Quote from: Rik on Dec 16, 2008, 08:34:47
Wash your mouth out !  ;D
