Zone Alarm update.
Started by maxping, Jan 19, 2007, 18:11:03
maxping
> Zone Alarm version 7.0.302.000
I used the update link in ZA but it didn't tell me i needed one.
I have found a link here - http://www.softpedia.com/get/Security/Firewall/ZoneAlarm-Free.shtml
Nerval
I packed ZA in a while ago when it started playing up.
Just use the router and windoze firewall - seems ok so far touch wood.
ou7shined
I'm a router/avast man meself. Can't stand Win Firewall - I always disable it. :P
Rich.
Klaatu barada nikto!
Nerval
Why's that?  I never notice it.
maxping
WF only blocks  traffic one way so i have always used ZA & my routers firewall, belt n braces  :D
ou7shined
I guess it stems from my early attempts at p2p and not being able to configure it properly, that and it only updates once a month, but by all accounts it's not all that good at catching stuff anyway - not so important if your router is a tight as a ducks I guess. The thing I like best about avast is that it updates at least once every day.
Rich.
stevelondon
same here updated it from file hippo the other day cos Zone Alarm said no update
Quote from: Nerval on Jan 19, 2007, 19:29:51
So did I, I did a test on my computer and it showed up secure.
maxping
#8
Quote from: ou7shined on Jan 19, 2007, 20:03:38
AVG also updates  every day but i use the manual method rather than rely on the auto option, again belt n braces  :laugh:
If you want to check your set up for security have a play here - https://www.grc.com/x/ne.dll?bh0bkyd2
Click the proceed button then use the file sharing,common ports & all service ports.
They should all show "stealth"  ;)
stevelondon
Try this leaktest see if your firewall is doing its job  LeakTest
stevelondon
lol max must have posted at the same time
