memory
Started by Baz, Dec 23, 2008, 20:58:58
where do people buy their RAM from
Philip
yeah that would be my first place to look, any where cheaper but still good memory.
MoHux
I have recently put 'Kingston' on the new m/b I fitted.  2x1mb matched.  So far no problems after a month or twos use Baz.   :fingers:
Mo
:santa2:
P.S.  Yet another Xmas Baz.
        Have a good one!!
:mxmas: :hny:
thanks Philip and Mo. Im open to any suggestions.
Yep it soon comes round Mo doesnt it. hope you have a godd 'un too all the best mate :mxmas:
Quote from: Baz on Dec 23, 2008, 20:58:58
Can't remember. :)x
But seriously, Crucial for me too.
JB
Quote from: Baz on Dec 23, 2008, 21:18:37
I put a couple of sticks of this in my last project:-
http://www.play.com/PC/PCs/-/2159/1426/-/5399823/PNY-PC6400-2GB-800MHz-DDR2-240pin-DIMM-Computer-Memory/Product.html?searchtype=genre
It checks out fine and does the job at a very reasonable cost. Probably not suitable for a gamers PC as the latency (CL) = 5, whereas CL=4 or less would be better for cutting edge fast applications.
Can't knock the price though.
JB
JohnUK89
Intel boxes don't mind too much what the latency is - it's made up for in raw clock speed usually. I've heard AMD boxes are somewhat more sensitive when it comes to RAM latencies though (Not got an AMD box myself now so can't test)
Is the world purple enough yet?
No.
Another vote for Crucial here. It's simple to find and quite decent. Their service is good as well. :)
Crucial for me too, you can save a few bob elsewhere, but do you want to.
Crucial are the IDnet of memory suppliers
another vote for them from me too!
Branded stuff on ebuyer should be fine too! :out:
OCZ or Corsair here, just got three 2GB sticks of Corsair DDR3, Crucial is good but I would personally not touch Kingston unless it was for an older box with something like a pentium D in but there are great deals to be had on DDR2 right now its really cheap, I use custom pc quite a lot
Quote from: Killhippie on Dec 23, 2008, 23:14:06
........Crucial is good but I would personally not touch Kingston unless it was for an older box ........
I've always used Kingston (not the ValueRam) in all my Macs since forever, including the laptops which can be choosy over memory, and had no problems.
A friend has used Crucial with no trouble.  I don't think either is the cheapest around, but they do appear to be reliable.
Crucial or Corsair for me.
I have used Samsung, Hynix, Crucial or no Brand, all worked fine, never had a problem.
I reckon that it is all made in 2 or 3 factories and just batch labelled anyway. ;D
It probably is, In. What they used to do was test it and then allocate a speed rating after testing, so the slower RAM was the same as the faster, only not as reliable.
JB
I have usually used Crucial over the years and found them excellent.
I had my first stick of Crucial memory go faulty a few weeks ago after one years use. The RMA was handled competently, complicated by the fact that the matching stick of the pair is still in a computer in Spain.
I'm inclined to agree that there are probably only a handful of memory makers these days anyway. Much the same as blank CD or DVD media. Crucial are good if you have a problem. That said, the less expensive PNY memory I mentioned above is superb and gets very good reviews.
Good luck with whichever make you buy Baz.
JB
vitriol
I tend to use either Crucial, Corsair, OCZ or Kingston (depending on the budget I'm working with)  Crucial is my fave though.
BrianM
Ordered mine from Crucial earlier this year, bought a 512mb card to try first, that was ok so bought a 1gb, fitted that, no problems. Both were delivered within two days of ordering.  :thumb:
Brian
Take care of all your memories. For you cannot relive them.
JohnUK89
I'm running on Corsair myself and for everyday usage it's perfect. Overclockers will want different RAM though :D
No.
D-Dan
Unless you are planning on overclocking, you should be fine with any memory rated at the fastest your box can handle. If you do intend to overclock, then go for good branded memory, possibly at a higher speed than you need.
Have I lost my way?
MoHux
I used Kingston because it was the recommended memory by the manufacturers of my new m/b, 'Gigabyte'.
Running TOTRange games without problem.
Have used Crucial in the past, also excellent.
Mo
:santa2:
Quote from: Tacitus on Dec 24, 2008, 07:48:44
I was meaning the value ram, I should have said that  :)
RA-1972
I have always bought mine from , overclockers or ebuyer you can get some good deals . i use corsair 2 gig matched pair .
ok then can you explain what the figures mean with memory. My mobo manual says it will take ddrll 400/533/667/800 when you search crucial it states it as  DDR2 PC2-6400,DDR2 PC2-8500,DDR2 PC2-5300
whats the best to get
